Mirror drip
Old Jun 6, 2010 | 09:59 PM
Smooth9883's Avatar
Smooth9883
Default Mirror drip
Has anyone found out the secret to stopping the water from dripping down the doors after you wash your car?
I'll dry the mirrors really good and do it for about 30 mins after I washed the car. I'll then go in the house come out two hours later to water stains down the door.
Old Jun 6, 2010 | 10:06 PM
jeffjob's Avatar
jeffjob
Melting Slicks<br><img src="/forums/images/ranks/3k-4k.gif" border="0">
St. Jude Donor '13, '17-'18, '25
The secret is to gently lift the mirror as you dry, (better done if you are blowing Vette dry) and the colunm of water will drain.
I have tried the mirror covers but the problem is the water collect in the base. Lifting gently, (only as much as needed) will allow the drainage.
Devind100's Avatar
Devind100
I was going to ask the same question today. Im all ears for someones input.
Old Jun 6, 2010 | 10:07 PM
QUAKEJAKE's Avatar
QUAKEJAKE
Air compressor or leafblower can be your friend in the Vette washing department.
Old Jun 6, 2010 | 10:12 PM
mliebs's Avatar
mliebs
I use a leafblower before I dry the car off, it works great.
Old Jun 6, 2010 | 10:48 PM
easyrider13's Avatar
easyrider13
My electric Toro blower works fine although my gas blower works even better.
Old Jun 6, 2010 | 11:07 PM
Wayne O's Avatar
Wayne O
CF Senior Member
I use an air compressor as well.
Old Jun 6, 2010 | 11:11 PM
Epic_C6's Avatar
Epic_C6
I use an Air Blaster that I bought for my motorcycle and it works great. It filters the air and heats it up a little bit to more effectively dry than just blowing with a leaf blower. I don't have to use towels at all and I get no drips from my mirrors or tail lights.
Old Jun 6, 2010 | 11:40 PM
LMB-C6's Avatar
LMB-C6
Had the same problem until I started using the leaf blower. It removes most of the water, the rest goes pretty quick using a chamois. Funny thing is I bought the leaf blower just for this purpose and it sat in it's box for a year before I started using it
Old Jun 6, 2010 | 11:42 PM
cmonkey713's Avatar
cmonkey713
Simply wrap them with a clinging food wrap like Seranwrap. Keeps the water out.
Old Jun 6, 2010 | 11:49 PM
4-Sho's Avatar
4-Sho
No Guts - No Glory
Only my passenger-side mirror seems to hold a lot of water and will drip for a while after I wash the car. After I dry the entire car I'll hold a papertowl to the base of the mirror and let it absorb most of the water. Then I'll continue detailing the car (wheels tires, windows, interior, etc) and return to the mirror a little while later to see if it's still dripping. Usually after absorbing the water with a papertowl a 2nd time it doesn't drip anymore.
Old Jun 7, 2010 | 12:06 AM
Marc V.'s Avatar
Marc V.
How do you wash the mirror?
Compressed air is the answer. Dries water from all nooks and crannies.
Old Jun 7, 2010 | 12:39 AM
cclive's Avatar
cclive
Me too, great for the nooks in the wheels also.
Old Jun 7, 2010 | 01:43 AM
WMark's Avatar
WMark
St. Jude Donor '11
I prefer the air compressor. Where I live, no need for a leaf blower. Both work well. However, you can use the compressor for a bunch of other neat stuff.
Tip... After rinsing the car, **** the mirrors down. While you are blowing off other water holding areas, let them drain. Then blow the heck out of 'em. Focus on the base.
The air compressor/leaf blower also rids you of other water holding problems. Rear tail lights, front and back emblems, etc.
Get a compressor, or a leaf blower and problem solved.
Old Jun 7, 2010 | 05:18 AM
Slogo's Avatar
Slogo
wash the car on a hill,front of car pointed up. Shop vac sucks water out of all cracks.
Old Jun 7, 2010 | 07:00 AM
cylon's Avatar
cylon
love the simplicity of the solution - thanks!
Old Jun 7, 2010 | 07:16 AM
FortMorganAl's Avatar
FortMorganAl
From: Currently somewhere in IL,IN,KY,TN,MO,AR,MS,AL, or FL
People also used to complain about water from the tail lights and there is/was a seal you could buy for the tail lights. I've never had a problem with either but I also always use a leaf blower. I seldom touch the car with anything during drying so I also don't have any swirl marks.
To Mirror drip
Old Jun 7, 2010 | 07:34 AM
GSRANDY's Avatar
GSRANDY
I use my Master Blaster to blow off my mirrors, helps the situation, however water still runs down both doors for period of time, just not as much.
I find myself going back with my micro-fiber towel and wiping the water off of my doors a few times and then all is well.
Regards,
GSRANDY
Old Jun 7, 2010 | 08:04 AM
frogmore's Avatar
frogmore
wrap them with depends underwear for a day or two......wife went thru menapause, no more kotex in the house.
Old Jun 7, 2010 | 11:40 AM
rakuhn's Avatar
rakuhn
Good advice so far. I use one of those Master Blaster's to dry the Vette after washing it. It certainly clears water from around the lights, rims and moldings extremely well.
Nope, I do not have to use anything else to dry the car with. Prior to purchasing the Blaster, I used the leaf blower and it did a pretty good job.
