Tire Pressure
Old Jun 11, 2010 | 07:38 PM
stoessjc's Avatar
stoessjc
Default Tire Pressure
My alignment guy said to run 34 psi cold pressure in the tires. I told him the manual calls for 30 psi cold. He claims that is why they wear the sides out. Any responses?
John
Old Jun 11, 2010 | 07:42 PM
dvilin's Avatar
dvilin
News to me, I never heard that before I go with what the manual suggest.
Old Jun 11, 2010 | 07:46 PM
99c54me's Avatar
99c54me
I'm sick. I measure and record tire depth and keep track of it. It's a problem, I can't shake it, I'm an engineer.
I run 32 in front, 30-31 in back (cold of coarse)
My measurements show the fronts need more than 30 and 32 seems to be perfect for my alignment setup (-0.6 camber).
My guess is 34 in front would be to much for me.
32 in back is to much for mine, shows uneven wear. do what works for you.
Old Jun 11, 2010 | 07:52 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
what alignment are you running that he recommends that? the 30 recommended is for the specs from the factory based on the tires, the car, the weight, etc. if you're running something different, I'd say maybe.
but as seen above, it has to do a little bit with your driving style, too. how have your tires been wearing across the tread, front and rear and tire by tire? feathering, cupping, even tread depth, etc.
Old Jun 11, 2010 | 09:13 PM
VET4LES's Avatar
VET4LES
30 in front works for me but not in the rear. 30 caused the center to wear faster than the edges so I lowered the rear to 28. So far it's working. I have 26,000 miles on the rears and should get another 5 or 10,000 out of them.
Old Jun 11, 2010 | 10:11 PM
cclive's Avatar
cclive
34 in the rear is going to make a nice smooth stripe right down the middle of the tire.
Old Jun 11, 2010 | 10:50 PM
wolfdogs's Avatar
wolfdogs
From: Stafford VA, home of our wolf den. No house break ins to date.
Run the O.E. pressure folks. A lot of testing went into that for a reason........ I will admit I add 2 psi to the front, but thats it. Tires wear for a reason...... that reason is they are doing their job........ if the crown edge wears, it means its grabbing in the corners..... if you over inflate.. you are not using the crown edge, henceforth, you are loosing performance from the car...... your front tires will break loose much quicker..your foot print is smaller.
In order to receive the performance you expect from a car such as a Corvette, or other high performance cars, there is a trade off.... the tire. The tire is the link to the pavement that transforms all that engineering from that auto to what it is....... and its going to wear.. if it didn't wear, then you won't receive the performance.... its like the line on your weedeater, the grip on your golf clubs, tennis racquet, the soles of your running shoes........
Old Jun 11, 2010 | 10:53 PM
Wayne O's Avatar
Wayne O
CF Senior Member
I run an extra 1-2 lbs in the front to help compensate for the car's 51/49 weight distribution ratio. It works well for me.
Old Jun 13, 2010 | 02:34 PM
stoessjc's Avatar
stoessjc
Thanks for the responses. With the stock wheels, I ran 30 front and rear and got 36,000 out of all four tires. The fronts had cord showing on the inside edge when I removed to do the wide body mod. The rears probably have a few thousand left before reaching the tread wear indicators. I think I will stick with 30 all around, as that proved well with the original tires. I had the alignment done to factory stock specs.
John
Old Jun 13, 2010 | 02:45 PM
Easy Rhino's Avatar
Easy Rhino
From: Middle TN by way of KY, OH, VA, IL, CA, FL, NY, SC, HI
Depends on the tires, the load, the temperature where you use them (including temp. gain under use) and the use (track, town, highway). 30 is a good cold nominal start. Going much above 30 will imporve mpg, but the difference may be eaten up in more frequent tire replacement costs. That said, low pressure is never good.
I too, am an engineer and measure my tires 2x year. I am getting over 42K miles out of my OEM GS2s rears, and the tread wear is within 1/64s across the tread.
So far they are wearing out pretty evenly across the entire tread. If I went to 34, they would be bald in the middle early.
Oh, and check that alignment.
Old Jun 14, 2010 | 03:34 PM
tims92's Avatar
tims92
I just upgraded my C4 to a C6 yesterday... All I can say is Wow!
The seller had just replaced the front tires with Ohtsu non runflats and pumped them up to 45 psi. Now I get an over pressure warning. 45 psi is way too high for these tires (50psi max rating). In any case, how should I determine the best psi or should I just start at 30 psi and see how it goes?
Old Jun 14, 2010 | 03:38 PM
IDSRVIT's Avatar
IDSRVIT
So to clarify Wolfdog, you run 32 in the front; and 30 in the back?
Old Jun 14, 2010 | 04:05 PM
Dave S's Avatar
Dave S
Retired & lovin' it!
Alignment I'm running is Front 7.85 degrees Caster; negative 0.45 degrees Camber; 0.02" Toe.... Rear negative 0.48 degrees Camber; 0.00" Toe. With this set up & Nitto Invo's, I'm running 32 lbs (cold) all around. Get great steering response, especially on turn-in & excellent tire wear.
Old Jun 14, 2010 | 04:13 PM
jamesbertero's Avatar
jamesbertero
Sage advice. Why do we think we can outsmart people who spent so much time and money to come up with a DOT approved rating and rec pressure? I think it is the "tinkerer" in all of us gearheads. It has taken me a long time to quit "F'ng" around with it and stick with stock. Now, if I were going to start tracking my car.......
Old Jun 14, 2010 | 04:31 PM
cclive's Avatar
cclive
The seller was an idiot to have any tire on a C6 pumped to 45 psi. Tire pressure has more to do with the car and the tire size, rather than the tire make. For the stock size tires, the right pressure is around 30. The max rating on the tire sidewall has nothing to do with the pressure that should be in them for driving. It has more to do with how much air can be put in them to seat the bead when mounting them.
Old Jun 14, 2010 | 04:36 PM
jamesbertero
Wow, I didn't catch that! 45lbs!!
Old Jun 14, 2010 | 06:24 PM
tims92's Avatar
tims92
Yah. The seller destroyed the front tires because he didn't care about low air pressure. Then, the seller's regular tire guy pumped up the new tires to 45 psi the day I picked it up. Never go to Les Schwab.
Old Jun 14, 2010 | 06:41 PM
wolfdogs's Avatar
wolfdogs
yes, but in reality.. a tire (street tire..not racing tire/track only) will only recognize (performance wise) increments of 3psi.
To Tire Pressure
