Time to settle a friendly "discussion". Will running 87 octane in a C6 actually damage anything or just reduce performance? (Lets avoid the "If you can't afford the high octane gas, you shouldnt be driving a vette anyway...." stuff. Thats not the issue.. I have 50 bucks and a case of beer on the line!
Please no trivial opinions - just the facts please! I'm thirsty!
Here's what my 2006 owner's manual says on page 5-5.
If your vehicle has the 6.0L V8 engine (VIN Code U),
use premium unleaded gasoline with a posted octane
rating of 91 or higher. You may also use regular
unleaded gasoline rated at 87 octane or higher, but
your vehicle’s acceleration may be slightly reduced,
and you may notice a slight audible knocking noise,
commonly referred to as spark knock. If the octane is
less than 87, you may notice a heavy knocking
noise when you drive. If this occurs, use a gasoline
rated at 87 octane or higher as soon as possible.
Otherwise, you might damage your engine. If you are
using gasoline rated at 87 octane or higher and you hear
heavy knocking, your engine needs service.
If your vehicle has the 7.0L V8 engine (VIN Code E),
rating of 91 or higher. For best performance, use
rating of 93. In an emergency, you can use regular
unleaded gasoline with an octane rating of 87 or
higher. If 87 octane fuel is used, do not perform any
aggressive driving maneuvers such as wide open throttle
applications. You may also hear audible spark knock
during acceleration. Refill your tank with premium fuel
as soon as possible to avoid damaging your engine.
If you are using gasoline rated at 91 octane or
higher and you hear heavy knocking, your engine
needs service.
That says to me that 87 octane fuel is okay in a non-Z06 C6, but not in a Z06.
Higher octane helps prevents detonation - it does not "literally" make your car go faster. Granted, a motor that is "knocking" is not performing. //art
If the ECM detects engine knock, the ECM will retard the engine timing, resulting in less power.
Thus using higher octane allows for more engine timing, resulting in more power.
From: Currently somewhere in IL,IN,KY,TN,MO,AR,MS,AL, or FL
If you hear spark knock you are damaging the engine. Spark knock means the fuel has burned enough before the piston has reached the top of its stroke to create enough pressure to cause the piston to be pushed backward on the crank hard enough to make a pinging sound. That isn't good. Is it fatal? Not for a while but you are wearing the bearings a lot more than if there was no spark knock. You are also creating hot spots on the cylinder head and valves that will also eventually cause problems. You can get away with it for many thousands of miles but eventually you will be overhauling the engine while most engines that have been feed the recommended gas are still running like new.
I agree with FortMorganAl...if using lower octane fuel causes any abnormal engine knocking you're damaging the engine. Some may argue minor engine knock (resulting from the use of lower octane fuel) is of no consequence but it is causing excess wear and tear on engine components that would have been avoided by using the correct higher octane fuel. The 'computer' will compensate to some degree but it takes time. There's a reason the manufacturer specifies the use of premium (higher octane) fuel.
Maybe its just me making it up in my head --- but I felt the difference when driving (accelerating in particular) the one time I put in lower grade. I didn't notice any pinging noise, but to me the slight pickup and acceleration loss was noticeable.
Probably won't notice if you don't typically go after the "get to 5-10 over the speed limit on the on ramp" feeling
One misconception is that the engine is somehow sampling the fuel and retarding the timing according to the octane rating....this is not the case. The engine only retards the timing when the knock sensors sense the beginning of pinging. If you are cruising along on the highway at 80mph, lower octane fuel will not cause knock and the timing will not be retarded. It is only when the engine is worked harder that knock can begin on lower octane fuel...THIS is when the timing is retarded and power is lost. As soon as the gas pedal is released, the pinging stops and the computer returns timing to normal. The computer does not sample the octane of the fuel and retard timing accordingly. It only retards timing when pinging begins and returns timing to normal the instant pinging stops.
Last night I filled up at Shell put in their best names V-Max (or whatever it's called) rated for 92 octane (highest they had) but I was surprised to see it had 10% ethanol.
Any issues with that?
I can't find a single gas station in Sioux Falls higher then 92 octane or that doesn't have 10% ethanol.
Considering Ethanol has an equivalent octane rating of 110+ all it will do is help.
