In my 85' S-10, I replaced the white bulb in the rear view mirror with a red LED #194, now I can leave it on while driving, lights up the area below it very well..cost of the bulb, a buck..
I just discovered this light a year later in my 07 c6 I was fusing with my rear view and I looked up and saw it. I jsut searched for it thinking someone else must know about it and sure enough you guys are all over it! I must agree I need some brighter LED light bulb. Off to radio shack I go.
thx guys!
Ah Ha! After reading about the "little red light" (ambient) I had to go to the garage and have a "looksee", sure enough my 07 has one. Did not know it was there. I never turned the headlights on until tonight. Any more neat things I'm missing on this car? Now if I can figure why the clutch pedal pushes so hard.
Turn the car on, turn your lights on and look closely at passenger side visor where it clips in. you might want o unclip to see it better if you have it. Good luck
I wonder if anyone can figure how to get this on the driver side also. I would think having both driver and passenger would give off a very nice ambient lighting at night.
Would like to make a small addition to this thread. First I want to thank you guys for the information that the plug is still in the later cars. I will also add the OEM light. LEDs are rated at different voltages and currents. Most of the time a resistor is used to limit so the proper current can be used. When switching these LEDs out, it is possible that you might burn a few up if their voltage requirement is lower than that of the stock one. I do not have a schematic, but that might be a resistor in the short wiring extender after the bulb. In most cases, you shouldbe OK. If your different color LEDs are burning out a lot, you might need to change the resistor value. I think the value on the LED in the picture was like 1.8V @ 20ma. Edited to add web site to determine resistor. Use the values on the LED you purchase. http://ledz.com/?p=zz.led.resistor.calculator
