Engine Issue Question
Old Jul 14, 2010 | 11:09 AM
Deftly's Avatar
Deftly
Default Engine Issue Question
I was out driving, parked, then start the car back up and got a rough running engine with a DIC warning of "Reduced Engine Power"? It was as if the engine was running on 5-6 cylinders. The RPM would not get above 2500. After waiting for a bit I started the car again and it was as if nothing happened except the check engine light remained. A local Chevy dealer cound not duplicate the problem since no code was stored.
Anyone have a similar situation?
Old Jul 14, 2010 | 11:18 AM
Wayne O's Avatar
Wayne O
CF Senior Member
I've never had this but reduced engine power can result from over-heating...the system goes into an overheat protection mode and alternates firing groups of cylinders to prevent engine damage. Perhaps a fault related to detecting an overheat condition...perhaps a sensor? I'm not sure but good luck.
Old Jul 14, 2010 | 11:26 AM
Tom's_03SVT's Avatar
Tom's_03SVT
never had an issue with that either, has it happen again since?
Old Jul 14, 2010 | 12:22 PM
RicK T's Avatar
RicK T
Spurious gremlins do happen and have been talked about here so hopefully that's all it was. But I am curious, you say the CEL is still on but the dealer found no codes? Doesn't seem possible to me. Anyway, we all hope the best for you.
To Engine Issue Question
