Headlight No Power
Old Jul 28, 2010 | 07:40 PM
StLRick's Avatar
StLRick
St. Jude Donor '07
Default Headlight No Power
Issue:I had a diver side low beam headlight out. Buy a replacement bulb (not cheap by the way) and had it installed @NTB. (This shop is great service and good ) so The checked the fuse, it's good they check the power to the light and it has no power at all at the light. What could be the problem here. I have extended warranty and I am dreading the Chevy dealer ordeal...Any thoughts?
Old Jul 28, 2010 | 09:38 PM
RLSebring's Avatar
RLSebring
Supporting Vendor
From: Pensacola Florida GO GATORS!!! www.rlsebring.com www.c6c7vette.com
St. Jude Donor '17
Replace fuse. Sometimes a fuse will check out OK until power is applied it.
Next would be lo beam relay.
Does the harness have any power or just the low beam wiring has no power?
__________________
GO GATORS!!!
2008 Vert
Owned since new in 2007
www.c6c7vette.com
Old Jul 28, 2010 | 09:42 PM
johnodrake's Avatar
johnodrake
Moderator
Check the HID ballast.
Old Jul 31, 2010 | 11:51 AM
StLRick's Avatar
StLRick
St. Jude Donor '07
Well it turned out to be a short in the light assembly system. Had to be replaced. Cost $1400. my deductible was $250.
To Headlight No Power
