Old 02-20-2015, 05:39 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Exterior How-Tos
Print Wikipost
LOW OIL PRESSURE to ZERO OIL PRESSURE and NOW ENGINE RATTLE
Old 08-04-2010, 08:19 AM
Ahmer
Ahmer's Avatar
Default LOW OIL PRESSURE to ZERO OIL PRESSURE and NOW ENGINE RATTLE
I believe my car is toast. I was driving and went from Low Oil Pressure to Zero Oil Pressure in a matter of 30 sec.
What can possible do this??? Bad Oil Pump, Bad Lifter?
Old 08-04-2010, 08:25 AM
FortMorganAl
FortMorganAl's Avatar
Location: Currently somewhere in IL,IN,KY,TN,MO,AR,MS,AL, or FL
And the reason you kept driving for 30 seconds with low oil pressure was?
It might have been just a bad sensor but when you say the engine now rattles that's a pretty good indication there really was a problem and you kept going until, as you say, the engine is now toast. What was the problem? Does it really matter now? Even if it was just a failed oil pump the engine now needs to at least be rebuilt if not replaced.
Good luck.
Old 08-05-2010, 08:20 AM
Ahmer
Ahmer's Avatar
The reason was I was on a VERY busy intersection and could not have stopped until I pulled into a parking lot safely.
The car is at the stealership. What can possibly cause a "Low Oil Pressure"
Old 08-05-2010, 08:33 AM
ben dover
ben dover's Avatar
Location: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
Little or no oil, pump failure.
Old 08-05-2010, 08:35 AM
Ahmer
Ahmer's Avatar
The oil level was fine... I checked it immediately after getting out. Plus I was NEVER given a Check Oil Level Light.
Old 08-05-2010, 08:37 AM
dvilin
dvilin's Avatar
Received 7,929 Likes on 4,810 Posts
I would guess the oil pump if the oil level is okay, you certainly did not throw a rod or something of that nature.
Old 08-05-2010, 08:38 AM
kevakasper
kevakasper's Avatar
2017 C4 of the Year Finalist
No-IL Events Coordinator
St. Jude Donor '12-'13-'14-'15-'16-'17
That rattle you heard was it's death rattle, your toast. Low oil pressure means that...low oil pressure, you just spun a bearing, or a whole lot of bearings! I hope it was something internal for your sake and not something as stuiped as low oil. Low oil would mean lack of maintaince, which would mean no warranty if you had one. Good luck, let us know what happened.
Old 08-05-2010, 09:02 AM
BSE1956
BSE1956's Avatar
Please do follow up on this one.
Old 08-05-2010, 09:08 AM
FrankTank
FrankTank's Avatar
CI 7-8-9-11 Veteran
St. Jude Donor '06-'10, '13
Oh man, this is not going to be pretty. OP I am sorry, hope it is not as bad as we are all thinking but from what you described RIP your engine...
let us know what happens.
Old 08-05-2010, 10:06 AM
Wayne O
CF Senior Member
Support Corvetteforum!
Wayne O's Avatar
I'm sorry about your problem. From what you say it doesn't sound encouraging but keep a good thought. Did the oil pressure suddenly go from 'normal' to low to zero? Were you driving with low oil pressure for a while? What was the low oil pressure reading? Was this at an idle or was it low even under acceleration? Did you notice the engine rattle before you stopped or did you restart the car after pulling over? What were the circumstances....were you 'stressing' the engine? When I come off the race track (hot) its not unusual for my oil pressure to dive as low as 18 at an idle, however, if I give it some gas the pressures increases. After it cools down everythings back to normal.
I'm no expert but there can be many things which cause low oil pressure...a malfunctioning oil pump (stuck regulator valve, regulator valve spring, etc.), pressure relief valve, blockages, missing oil gallery plugs, valve lifters, electrical problems, filter problems, etc. Hopefully, its something relatively minor and engine damage, if any, will be minimal. Let us know what happens and good luck.
Old 08-05-2010, 10:07 AM
thesubfloor
thesubfloor's Avatar
Location: Brentwood World's first A6 in the 9's (including N/A, blower, turbo and nitrous cars) 9.950@139.267 CA
Believe it or not these engines (despite all the failures) can be pretty resilient. If the OP got the motor shut down quickly enough, the rattle sound he heard would have probably just been the lifters clacking from having been bled down and not necessarily because of a spun bearing.
The problem still needs to be addressed but you might not be looking at a complete catastrophic failure.
Old 08-05-2010, 10:13 AM
Racer's Avatar
Cruise-In III Veteran
St. Jude Donor '11
<<<<<<RIP>>>>>>
Old 08-05-2010, 10:44 AM
CodyC6
CodyC6's Avatar
Several TBSS' with the LS2 have spun bearings as well, but they have been attributing it to poor oil pick up because of the different type of oil pan. They have been monitoring the oil pressures with Dashhawks, etc and many have found their pressures dropping as you mentioned while accelerating. I've been hoping this is the oil pan issue, and not an LS2 issue as I have two. Let us know what they find. Good luck.
Old 08-05-2010, 12:02 PM
Ahmer
Ahmer's Avatar
Yea. I am afraid. So far no word from the dealer yet. Pray for me folks...
Old 08-05-2010, 12:23 PM
FrankTank
FrankTank's Avatar
CI 7-8-9-11 Veteran
Time to pray to the Corvette and LSx Gods
Was the car leaking any oil? I figure you might have mentioned if it was, but just curious.
Old 08-05-2010, 12:29 PM
dpigguy
dpigguy's Avatar
what dealer you using in Houston?
Old 08-05-2010, 01:06 PM
j_digi454
j_digi454's Avatar
Originally Posted by CodyC6
Several TBSS' with the LS2 have spun bearings as well, but they have been attributing it to poor oil pick up because of the different type of oil pan..... Let us know what they find. Good luck.
Yes, please let us know how it turns out.
To LOW OIL PRESSURE to ZERO OIL PRESSURE and NOW ENGINE RATTLE
Old 08-05-2010, 05:40 PM
jschindler
jschindler's Avatar
Same question. PM me if you'd rather not say, or just give us a clue.
Old 08-05-2010, 05:59 PM
CessnaDriver
CessnaDriver's Avatar
I bet your right. This may not be the end of days for that engine.
Old 08-05-2010, 06:36 PM
Ratchet Thunderbolt
Ratchet Thunderbolt's Avatar
Quick Reply: LOW OIL PRESSURE to ZERO OIL PRESSURE and NOW ENGINE RATTLE
