C6 Lowering process
Old Aug 13, 2010 | 02:06 PM
d.medic's Avatar
d.medic
St. Jude Donor '10
Don't think I have ever heard of anyone cutting the front bushing. I'm sure it has happened but man that would be LOW.
Old Aug 13, 2010 | 03:12 PM
yojack1's Avatar
yojack1
I cut exactly 1/3 (no more) on all four bushings then screwed them down all the way with a spot of grease on the pad.
Result, 1.5" drop. Add 8-washers (shims) to the 4-bolts (2 on each one) on the front upper control arm against the frame to correct the now increased negative camber. Then do or get a toe adjustment and your all set to go, SIMPLE!
20k miles later it still looks and works fine.
I have rarely scraped the bottom of the car and that's only over the largest of speed bumps.
Despite fear comments from what I call "lifted Vette" owners, if you know the limitations of your car, if you know how to drive it (not just fast), you should never have a problem negotiating speed bumps and driveways knowing what you have!
Heck, I could go off-road with the Vette compared to my NSX!
Jack
Old Aug 13, 2010 | 03:15 PM
C6VetteC_LOS's Avatar
C6VetteC_LOS
Jack
hahaha awesome...so when can i take my car to your house??
Old Aug 13, 2010 | 03:40 PM
yojack1's Avatar
yojack1
You wouldn't leave, disapointed!
Old Aug 13, 2010 | 03:46 PM
yojack1's Avatar
yojack1
If it's to low for you not to worry, just crank the screw in the opposite direction to raise to your desired ride height.
You need to come buy my house too! I like your car!
Jack
Old Aug 13, 2010 | 05:12 PM
d.medic's Avatar
d.medic
St. Jude Donor '10
Jack
I think the added weight of the forged motor and the supercharger is the reason my is so low in the front. I couldn't see going any lower. I've never been to the west coast.
Old Aug 13, 2010 | 05:24 PM
djdinoe's Avatar
djdinoe
Very nice all around! Cheers
Old Aug 13, 2010 | 07:02 PM
KevinZ51C6's Avatar
KevinZ51C6
If you wanna get low, you have to get the Hardbar bolts for the front also, yes they do make them specifically for the front also. You shouldn't cut the front bushing, but you can replace it. It depends on how low you wanna go, if you wanna be gangster like me, then...
http://forums.corvetteforum.com/c6-c...pics-here.html
Old Aug 13, 2010 | 07:40 PM
keyplyr's Avatar
keyplyr
The trouble with lowering via bolts is that your OEM shocks still travel the same distance but now you're lower, thus you will tend to bottom out quicker. Using adjustable coilovers you can lower waaay down while actually scraping less since the efficiency of the coilovers means less shock travel which eliminates that *Cadillac* bounce.
Old Aug 14, 2010 | 12:20 AM
yojack1's Avatar
yojack1
I've cut all the bushings and with the Magnetic (F55) I've never had any problem or bottomed out even at high speeds. Maybe it's different with other types. Thats over 20k miles and speaking with real experiece.
Jack
Old Aug 14, 2010 | 09:15 PM
ILLUSHN's Avatar
ILLUSHN
I just finished installing the hardbar rear lower bolts. I love the look. I had it lowered on stock bolts but the front sat so much lower then the rear. Could be from all the extra engine weight? Now that I have the rear at the same level the car scraps a lot less.
I'm sitting here looking at a set of bolts for the rear right now. I'm just waiting to get new tires before I install them!
Old Aug 15, 2010 | 05:51 PM
C6VetteC_LOS
Hey everyone..
so i lowered the front all the way without cutting bushings. The rear was also lowered all the way without cutting bushings. I will be cutting one layer of the rear bushing. For now i wanted to show you a quick look of my C6 converted to ZR1 body by ACS Composites, painted by New York Paint and Body and ADV1 Wheels.....Let me know what you think.
Old Aug 15, 2010 | 06:00 PM
  #33
timd38's Avatar
timd38
I gave up with bolts and went to coilovers.
Old Aug 15, 2010 | 07:28 PM
  #34
keyplyr's Avatar
keyplyr
Old Aug 16, 2010 | 06:51 AM
  #35
C6VetteC_LOS
Bump
Old Aug 17, 2010 | 08:13 AM
  #36
C6VetteC_LOS
bump
Old Aug 17, 2010 | 08:16 AM
  #37
C6VetteC_LOS
Here's another teaser shot. Car will be lowered in the rear today.
Old Aug 17, 2010 | 11:43 PM
  #38
JLP's Avatar
JLP
Factory bolts lowered all the way in front and Hardbar bolts in rear.
26 1/2" from ground to top of wheel well in front, 27" in rear. I really like
the stance now. Jim
