C6 Lowering process
Old Aug 11, 2010 | 08:38 PM
C6VetteC_LOS's Avatar
C6VetteC_LOS
Default C6 Lowering process
Just recieved my wheels for my C6 vette. 20x10 front and 20x13 rear. I basically did ZR1 front fenders, Z06 rear, Z06 front bumper, ZR1 Lip kit.
Now I'm thinking about lowering my Vette. I just bought Eibach lowering bolts and read a lot of vette guys are just using their stock bolts.
My car will be lowered and alligned on friday so i needed some input as fast as possible.
Please, if you have lowered your vette what did you use. Lowering bolts or stock bolts? how low did you go? If you have pictures of before and after that would be great.
instructions would be very helpful.....
I will be posting my before and after pictures soon. Thanks for all your help.
Old Aug 11, 2010 | 09:57 PM
geewez's Avatar
geewez
I too have 20x13" rear wheels with the wide body rear conversion. Too much of a gap between the top of the tire and the fender lip. Cranked the stock bolts all the way down but it only lowered the car about 3/4" so there is still a bit of a gap. I ended up buying a set of lowering bolts for the rear but haven't had a chance to install them yet.
Old Aug 12, 2010 | 02:35 PM
C6VetteC_LOS
Bump
Old Aug 12, 2010 | 03:13 PM
phxjeeper04's Avatar
phxjeeper04
Bought mine already lowered but will never lower another. Looks great but I drag on almost every speed bump! Mine was lowered almost 2".
Old Aug 12, 2010 | 03:21 PM
d.medic's Avatar
d.medic
St. Jude Donor '10
I just finished installing the hardbar rear lower bolts. I love the look. I had it lowered on stock bolts but the front sat so much lower then the rear. Could be from all the extra engine weight? Now that I have the rear at the same level the car scraps a lot less.
Old Aug 12, 2010 | 03:28 PM
C6VetteC_LOS
Any pictures
Old Aug 12, 2010 | 04:09 PM
427PWRD's Avatar
427PWRD
Not a widebody, but lowered on stock bolts, with one rib cut out of the back bushings.
Old Aug 12, 2010 | 04:57 PM
d.medic's Avatar
d.medic
St. Jude Donor '10
Originally Posted by C6VetteC_LOS
Any pictures
Maybe get you one tonight.
Old Aug 12, 2010 | 09:24 PM
d.medic's Avatar
d.medic
St. Jude Donor '10
Just some snap shots. Yes I know it's dirty but you get the idea
Old Aug 12, 2010 | 10:30 PM
St.Char's Avatar
St.Char
Front lowered all the way, the rears lowered all the way and bushings cut.
Old Aug 12, 2010 | 10:49 PM
C6VetteC_LOS
LOVE ITTTTTT......so one layer was taken off and the screwed the bolt all the way?
C6VetteC_LOS
awesome....
Old Aug 12, 2010 | 10:50 PM
C6VetteC_LOS
sick storm trooper look.....i actually was thinking of wrapping mine in matte white....
Old Aug 12, 2010 | 10:51 PM
C6VetteC_LOS
what about the front bushing?
Old Aug 12, 2010 | 11:45 PM
d.medic's Avatar
d.medic
St. Jude Donor '10
Don't cut them!
Old Aug 12, 2010 | 11:56 PM
C6VetteC_LOS
Don't cut them!
Ok so I guess I should lower my front all the way without cutting bushing and in the rear cut 1 layer and lower it all the way. Correct?
Old Aug 13, 2010 | 12:01 AM
d.medic's Avatar
d.medic
St. Jude Donor '10
If you never want to return the car to stock then cutting the bushings is the way to go.
http://www.vetteweb.com/tech/vemp_07.../photo_28.html
To C6 Lowering process
Old Aug 13, 2010 | 12:13 AM
yojack1's Avatar
yojack1
I feel like I know you!
Old Aug 13, 2010 | 08:45 AM
C6VetteC_LOS
Did you cut all bushings? or did you just lower the front all the way and the cut the rear bushings? if so, how many layers did you cut?
Old Aug 13, 2010 | 10:52 AM
C6VetteC_LOS
bump
