c6 front air diffuser
Old Aug 30, 2010 | 03:02 PM
MRMJCSIR52's Avatar
MRMJCSIR52
2nd Gear
Default c6 front air diffuser
already have popped a screw and air diffuser is separating from body..is it ok to take it off? seems you'd pick up 2" of ground clearance.
Old Aug 30, 2010 | 03:07 PM
07MontRedcp's Avatar
07MontRedcp
If you're talking about the front air dam then that helps to direct air up toward the radiator.
BJK
Old Aug 30, 2010 | 03:09 PM
MRMJCSIR52's Avatar
MRMJCSIR52
2nd Gear
black strip closest to the ground........touches ground so easily
Old Aug 30, 2010 | 03:10 PM
Scruff Vette's Avatar
Scruff Vette
No. The C6 gets it's air througth the nose grill in the front facia AND the bottom air dam which is designed to direct air up towards the radiator.
Old Aug 30, 2010 | 03:14 PM
jsims002's Avatar
jsims002
The middle one seems to be located for function, each side doesn't do much.
I tossed the two side ones after installing a front splitter, just trim it up a bit with some tin snips. JMO
Old Aug 30, 2010 | 04:20 PM
corvettemods1's Avatar
0corvettemods1
Former Vendor
St. Jude Donor '12-'13
We're running a sale on these replacements right now. Check out our thread!
Old Aug 30, 2010 | 10:32 PM
vetteright's Avatar
vetteright
The shorter left and right ones direct air into ducts just behind them which cool the front brakes. As has been said, the center one directs air to the radiator and the radiator also gets cooling air through the front grille - think that I read that its about a 60/40 ratio. 60 percent through the grille and 40 from the center spoiler. The side ones are easy to replace; just three 7mm screws attach each one to the car and a plastic push pin on each side attaches them to the center piece. It's about a 10 minute job to replace them both and about 30 bucks for the parts.
Old Sep 6, 2010 | 04:55 PM
markmott's Avatar
markmott
St. Jude Donor '16
You need it it helps cooling. There is a vendor on here selling them for < $100 shipped.
Old Sep 6, 2010 | 05:58 PM
JoesC5's Avatar
JoesC5
The front brake ducts are located in front of the air dam but the air dam does help with the air going into the ducts. The side air dam helps lower the aero drag by directing air to the outside of the car, around the front tires. Those wide tires really add to the car's drag and the air dam help to minimize the drag.
Old Sep 6, 2010 | 06:49 PM
vettedoogie's Avatar
vettedoogie
I'd like to remind folks that you change the basic functional design pieces at your own risk. The air dam is put there for a significant reason. Removing it can cause a change in engine cooling and for what? As much as it costs to do any engine repair, why take the risk for such a cheap piece of plastic? Just fix it.
To c6 front air diffuser
