Weight Reduction??
Old Sep 8, 2010 | 05:06 PM
corvet786c's Avatar
corvet786c
Default Weight Reduction??
Just wanted to know what else can we do to reduce weight on our 2008 LS3 vehicles. Has anyone compiled a list or how to?
Old Sep 8, 2010 | 05:28 PM
coolhand5599's Avatar
coolhand5599
It is best to start if you burn more calories than you take in .
In order to strip off enough weight that makes any difference you would make the car to where it is not enjoyable as a street driver. A couple of hundred pounds might only pick up a tent or so. You would probably spend less money if you bought a used super comp dragster and slap an LS3 on it. With a couple of cheap mods you would have an easy low 8 sec car.
You will destroy your car trying to pick up a 10th of a second by using weight reduction.I have been down that road before and I have always regretted it.
This is just an opinion of someone who has experience driving 250 mph funny cars.
Old Sep 8, 2010 | 05:36 PM
rmedina's Avatar
rmedina
Watch those carbs..
Old Sep 8, 2010 | 05:40 PM
Joe_Planet's Avatar
Joe_Planet
you say what else?
so what have you done?
Old Sep 8, 2010 | 05:41 PM
Vasta's Avatar
Vasta
St. Jude Donor '06-'07-'08-'09-'10-'11-12-'13-'14-'15-'16
Not that I know of.
These cars have been designed to be as light as possible. When Dave Hill was heading up the Corvette program, he put out a edict to his engineers working on the new C6. I'm paraphrasing here; If you want to add something to the car you must take away something so the weight stays the same.
The upcoming C7 is rumored to be 200 to 400 pounds lighter than the C6.
Old Sep 8, 2010 | 05:47 PM
corvet786c's Avatar
corvet786c
Originally Posted by Vasta
Not that I know of.
Wow I didn't know that? Yea but arn't they gettin smaller engines?
Old Sep 8, 2010 | 05:49 PM
LMBTom's Avatar
LMBTom
You can replace parts with their racing/lightweight versions (usually very expensive) or take stuff out that isn't necessary.
Lighter replacement parts:
carbon fiber hood/body panels
tires (non-runflat)
wheels
rotors/calipers
exhaust
battery
seats
windows/glass
coilovers
Remove:
radio/speakers
air conditioner
carpet/padding
power steering
You'll easily spend $10k on lightweight parts. That money is usually better spent towards performance upgrades.
Old Sep 8, 2010 | 06:03 PM
CO Lightfoot's Avatar
CO Lightfoot
Are you looking to build a gutted, dedicated track car?
Probably not.
Lots of ways to reduce weight... remove the passenger seat, carpet, insulation, audio & speakers, a/c, front sway bar, you-name-it.
And how much do you want to spend? Replace the drivers seat with a lightweight racing seat; non-runflat tires; lightweight wheels; etc etc etc.
A lot depends on your goal and your budget.
But if you're just looking for an easy way to lose a few pounds, keep in mind that Corvette engineers are well-aware of the performance gains from weight reduction. I'd bet if there's a simple, cost-effective way to save weight, it's already been done by the factory.
For example, why do you think the C6 battery is so small?
More ideas from the C5 forum: http://forums.corvetteforum.com/c5-t...reduction.html
And, of course, I have to say, there's always Jenny Craig.
Old Sep 8, 2010 | 06:07 PM
corvet786c's Avatar
corvet786c
Probably not.
hahahahahah no thanks I guess I will just build it up with more hp.
Old Sep 8, 2010 | 06:56 PM
Vasta's Avatar
Vasta
Wow I didn't know that? Yea but aren't they getting smaller engines?
Both. smaller engine=less weight plus anything else they can do to improve the power to weight ratio. It should keep the car just as fast or better than the C6.
Old Sep 8, 2010 | 07:11 PM
ospreycorvette's Avatar
ospreycorvette
The new Supercar Mclaren has a tiny 3.8 liter twin turbo, super light, about 2800 pounds with hugh HP, 600hp.
Old Sep 11, 2010 | 08:23 AM
hitech's Avatar
hitech
1st Gear
Why not get a lithium starting battery ?
around 3 lbs
Old Sep 11, 2010 | 08:41 AM
EDinPA's Avatar
EDinPA
Old Sep 11, 2010 | 08:42 AM
ospreycorvette
I have used that, works great.
Old Sep 11, 2010 | 01:55 PM
TRR's Avatar
TRR
Depending on what you want to do with your car when you get done, the best place to start is unsprung weight. I think the formula is one pound of unsprung weight is equal to 6 pounds of sprung weight. Someone might correct me if that's wrong. You can lose a lot of weight with two piece rotors, lighter wheels, and ditch the runcraps.
TRR
Old Sep 11, 2010 | 02:53 PM
HOXXOH's Avatar
HOXXOH
The first question to be asked before a reasonable expected answer is:
What is your intended purpose for reducing weight?
Gas mileage?
Road track?
Dragstrip?
Get within the GVW limits, so your girlfriend can ride with you?
Old Sep 11, 2010 | 02:58 PM
Easy Rhino's Avatar
Easy Rhino
From: Middle TN by way of KY, OH, VA, IL, CA, FL, NY, SC, HI
Get the 1LT - no options, less weight.
To Weight Reduction??
Old Sep 11, 2010 | 02:59 PM
slacker1201's Avatar
slacker1201
Lifetime NCM Member #2497
Cruise-In 9-10-11-12 Veteran
That is the rumor!
Old Sep 11, 2010 | 03:13 PM
keyplyr's Avatar
keyplyr
I had my '05 vert under 3k for a while; back up a few pounds now after some sweet additions, but easily reduced again if I want to.
Old Sep 11, 2010 | 05:54 PM
vdaddy's Avatar
vdaddy
The easiest way would be to get a Lotus.... my '05 weighs 1851 lbs. With a supercharger, power to weight is similar to our C6s. Handling is in a different league though Unfortunately, so is confort
