Weight Reduction??
Old Sep 12, 2010 | 08:13 AM
toomuchcar's Avatar
toomuchcar
Save 30+lbs (Z06/GS) with 2-piece rotors AND get better handling and performance. These come standard on ZR1 and all other high end sportcars.
Old Sep 12, 2010 | 09:44 AM
haljensen's Avatar
haljensen
Want extreme weight reduction? Read the latest issue of Hot Rod magazine. They take a C4 down to an open wheel racer and document weight loss and track times step by step.
Hint; Weight loss doesn't always result in better times. Suspension loading and aerodynamics are important too.
Old Sep 12, 2010 | 09:52 AM
Wayne O's Avatar
Wayne O
CF Senior Member
A road racing friend of mine did the following to shed some weight on his modified 2005....removed carpet and insulation; removed both seats (installed 1 racing seat); replaced the hood with a lighter, vented hood; replaced both doors with 'shell' doors; replaced the rear hatch with a 'stripped-down' hatch with Lexan instead of glass. Even the inside support struts on the shell doors have been drilled wherever possible. He says he shed 220 lbs. He's got all the pieces-parts that came off the car...given a day or two he can put everything back the way it was.
Old Sep 12, 2010 | 09:58 AM
User 81424's Avatar
User 81424
And he shed weight that was up high, the only better place to shed weight is the un-sprung weight of the wheels, tires, and brakes.
The question to the OP has already been asked but here it is a again, do you want a GT or a sports car?
Facts
1. You don't drive your car at 10/10ths on the street.
2. Based on #1 you can't tell the difference when you have a passenger or not.
3. Based on #2 you can't tell the difference of major PITA weight reduction mods.
So do mods that you can feel on the street like suspension, engine, exhaust, radio, etc.
Old Sep 12, 2010 | 02:23 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Another weight issue is stuff we add into the car.
In our C5, which had more storage room (center cubby in trunk), I took everything out of the car and weighed it all. Came to something like 65 pounds. That included a really good/heavy set of jumper cables, folding shovel for winter, etc.
In our C6, I've slimmed things down and the misc stuff is probably more like 25 lbs. But our Blockit sound matts add 25 more, and the cocomats probably another 5-10.
Since our cars are around 8 lbs/hp, every 8 lbs you add is like losing 1 hp. In my case, about like losing the 6 hp I gained from the NPP. For DD and touring, not an issue. For track, I'd throw it all on the ground.
Old Sep 12, 2010 | 03:52 PM
HOXXOH's Avatar
HOXXOH
Other than the car's an '08 C6, I know nothing specific enough to comment further. I have made several weight reduction changes to my '08, F55, A6, coupe for drag racing purposes, but they don't all apply to other needs.
It makes no sense to describe how I saved 101# of rotating weight, if the OP has no interest in drags.
