How do you....
Sep 13, 2010 | 11:58 PM
How do you....
How do you know if a corvette has the Z51 package? Is there a way to tell.....
Sep 14, 2010 | 12:04 AM
Look for "Z51" on the white sticker in the glove box.
Sep 14, 2010 | 12:12 AM
Quote:
Originally Posted by
JimTN
ok thanks! any other ways?
Sep 14, 2010 | 12:49 AM
Z51 equipped cars have 13.5" cross drilled rotors.
Sep 14, 2010 | 12:54 AM
GS-Zero
So do 2008 and newer F55-equipped cars. And 2011 J55-equipped cars.
Sep 14, 2010 | 12:59 AM
mpuzach
Z51s have a slightly manlier presence.
Sep 14, 2010 | 01:02 AM
mpuzach
2005 c6
Sep 14, 2010 | 01:12 AM
JimTN
The glove box will show all option codes the car originally came with from the factory.
Sep 14, 2010 | 01:19 AM
Mike's LS3
ok thanks guys
Sep 14, 2010 | 11:00 AM
The easiest way is to look under & behind the front bumper, on the driver side.
There is an oil cooler mounted on brackets in front of the radiator.
Sep 14, 2010 | 11:04 AM
GS-Zero
I had my '08 JSB Z51 coupe parked next to a '08 JSB Z06 and my friends let me know they thought the two cars were a "His and Hers" matching set.....
Sep 14, 2010 | 11:22 AM
car2fast4you
Learn something new every day. Didn't know that was easier than looking in the glove box.
Sep 14, 2010 | 11:26 AM
2015 C7 of the Year Finalist
car2fast4you
Um, I don't think I have a cooler located there. IS yours an A6? My M6 doesn't have that cooler.
Here is that area on my car and it may have a super charger coil there, it doesn't have an oil cooler.
I think the glove box is way easier!
Elmer
Sep 14, 2010 | 11:58 AM
Also, any of the Z51 features can be added by the owner except for the Z51 code on the glovebox sticker.
Sep 14, 2010 | 11:07 PM
St. Jude Donor '16
Sep 15, 2010 | 12:40 PM
St. Jude Donor '13
car2fast4you
JimTN
The oil cooler is installed only on the manual tranny cars.
We had a 2006 Z51 A6 and now a 2009 Z51 A6, no oil cooler on either one.
Sep 15, 2010 | 01:09 PM
Cruise-In III Veteran
St. Jude Donor '11
GS-Zero
except for the ghey emblems the manly men put on it.
Sep 15, 2010 | 02:51 PM
If I'm getting the OP's intent of the question, "is there a way to tell if a Vette is Z51 equipped by a casual glance of the exterior of the car"............nope (barring aftermarket badges).
Sep 15, 2010 | 03:36 PM
Gearhead Jim
Hey, I'm serious now!
I was just under the car when the super charger coil was installed. There was NO oil cooler sitting separate from my radiator. I supplied a picture. I have the 2007 Z51 with the MZ6. No separate small cooler found. We did not remove ANY cooler for this install. I was given a bracket to use HAD WE HAD the cooler. Did GM short me a cooler!
Back of radiator
Front of radiator
Front of radiator
Elmer
Sep 15, 2010 | 03:49 PM
I think the cooler is right there in the first picture...it's in front of the engine just ahead of the front crossmember....Yes?
