Question About Prolonged Jacking/Lifting
Old Sep 27, 2010 | 02:00 AM
Compaq's Avatar
Compaq
Default Question About Prolonged Jacking/Lifting
I wanted to have the curb rash on my front wheels corrected.
I found a place that does excellent work but they may need the wheels for a couple of days.
Does anyone see an issue with me leaving the front of my C6 in the air supported by 2 jack stands at the "preferred jacking locations"?
Thank you.
Old Sep 27, 2010 | 09:45 AM
Wayne O's Avatar
Wayne O
CF Senior Member
I generally use a floor jack with an adaptor beam (augmented with jack stands) but IMO you'll be fine. Set the parking brake and chock the rear wheels. I don't know how you're lifting the car but the frame is a solid support as well (using jacking pucks at the oval frame slots).
Old Sep 27, 2010 | 09:54 AM
Compaq's Avatar
Compaq
I was going to lift the car (evenly as I can) using 2 hydraulic floor jacks under the jacking puck sites on both the front driver's and passenger side. Then lower the car onto the preferred jacking locations.
Old Sep 27, 2010 | 01:18 PM
The Clevite Kid's Avatar
The Clevite Kid
St. Jude 15 Year Donor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16,'17,'18-'19-'20-'21-'22
Your plan will work fine. You gonna draft a spouse, or better yet a gear-head friend to run one jack while you run the other?
To Question About Prolonged Jacking/Lifting
