Clock Question
Old Nov 10, 2010 | 01:09 PM
LMB-C6's Avatar
LMB-C6
Originally Posted by Radioman
Clock? Don't need no stinking clock!
That's why I have a Corvette Wrist Watch (RPO CWW)....
Ah, the $2.00 Chinese copy of a Taiwanese imitation Timex, add a Corvette logo, and sell for $99.00
Originally Posted by Marc V.
Just wait 6 more months and your clock will be correct again.
Or just move 1 time zone over...problem solved!
Old Nov 10, 2010 | 01:18 PM
Larry/car's Avatar
Larry/car
Set your clock to Zulu time, it is never wrong. Then all you need to do is subtract your time zone hours from it. Example: Zulu Time - 5 hours = Eastern Standard Time. Set your clock to the 24 hr setting, makes the math easier
Old Nov 10, 2010 | 01:39 PM
DriverC6's Avatar
DriverC6
Originally Posted by CQRT
That's one of the things we have come to appreciate living in Arizona - -we never change time. Evidently, it was a concept that escaped the founders.
And the LAST thing you need in AZ is another hour of heat!
Old Nov 10, 2010 | 02:20 PM
kevakasper's Avatar
kevakasper
2017 C4 of the Year Finalist
No-IL Events Coordinator
St. Jude Donor '12-'13-'14-'15-'16-'17
Originally Posted by GOLD72
I thought the flux capacitors became obsolete with the C6 Gen cars??
They integrated the Flux Capicator into a chip in the radio now but it was only available on the 3LT on up cars......Sorry.
Old Nov 11, 2010 | 03:05 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
As everyone has figured out, the car clock needs to be reset manually. Your cell phone is automatic because the time is sent from the nearest cellphone tower.
What no one has mentioned is that you need to set your C6 clock twice- once for driver 1, then punch the memory button on the door for driver 2 and set the clock again.
My wife and I are sometimes on different wavelengths in the car, but never in different time zones.
Old Nov 11, 2010 | 03:28 PM
hpclj's Avatar
hpclj
Originally Posted by DigitalWidgets
I'm sure it's because the GM clock was designed before daylight savings time was proposed in 1895.
Bingo.
Old Nov 11, 2010 | 04:28 PM
schmegeggie's Avatar
schmegeggie
GREAT SCOTT!!!!
Old Nov 11, 2010 | 08:14 PM
Knob Jockey's Avatar
Knob Jockey
St. Jude Donor '11-'12-'13-'14-'15
For the 2K11 model year the Flux Capacitor was upgraded to the Oscillation Overthruster from Yoyodyne Propulsion Systems.
Unfortunately with this option installed your clock will enter a countdown mode, with zero hour being somewhere around Dec. 21, 2012.
Tinfoil is your only salavtion.
Old Nov 11, 2010 | 08:50 PM
lh4x4's Avatar
lh4x4
I put mine away and don't drive it until DST returns next spring!
Old Nov 11, 2010 | 09:26 PM
mack morrow jr's Avatar
mack morrow jr
If it has NAV the procedure is different. With ignition on go to the music notr under the source button with radio off. Touch the clock icon at the middle bottom of the screen. The rest will be self explanatory or just look under nav in your manual and look for time.
Old Nov 12, 2010 | 02:42 PM
cobraduke's Avatar
cobraduke
Read clock setting in the owners manual.
Old Nov 12, 2010 | 02:46 PM
kevakasper's Avatar
kevakasper
Originally Posted by Agent White
Hell, I reset mine and now it's showing military time!
Hit either the hr or min button until it flashes, then hit your tuning **** once to toggle through am/pm or military time.
Old Nov 12, 2010 | 02:51 PM
  #33
Vette_DD's Avatar
Vette_DD
This information was not in the 2005 owner's manual, but it was in 2006 and later ones. AFAIK, it's still in the newer manuals, but I've not looked.
Old Nov 12, 2010 | 03:13 PM
  #34
mack morrow jr
You can do a search on the internet for whatever year owners manual you want and it will come up in total. I use it all the time to keep from pulling out my owners manual from the rear storage bin since it is a tight fit for the glove compartment. Keep in mind that if you have Nav you must set it with the satellite having a view of the sky, And you must set it every 6 months as it is not like a mobile phone and set itself.
