VIS request
Old Nov 22, 2010 | 07:38 PM
juyanith's Avatar
juyanith
Default VIS request
I'm looking at a 2005 and the RPO list on comp nine isn't showing Z51 although the seller says that it is. I will check the car in person, but in the meantime could someone run a VIS check?
1G1YY24U955114845
Thanks in advance.
Old Nov 22, 2010 | 11:36 PM
lkelliott's Avatar
lkelliott
Your car has the MN6 Manual transmission so it can't have the Z51 package. The Z51 package calls for the close ratio MZ6 manual transmission.
Here is your print out of RPO codes on your 2005 Corvette.
Kent
Vehicle: CORVETTE 2 DR
Year: 2005
Build Date: Unk.
Found 26,728 vehicles matching your year and model in our database.
RPO Description Matches
UE1 COMMUNICATION SYSTEM VEHICLE, G.P.S. 1 GPS 1 VEH COMM SYS(UE1)
13,216
UG1 OPENER GARAGE DOOR, UNIVERSAL UNIVERSAL GARAGE DR OPENER(UG1)
22,378
UJ9 INDICATOR, LOW TIRE PRESS,TIRE PRESS MONTORING SYSTEM(TPM) LOW TIRE PRESS MONITORING SYS IND(UJ9)
25,227
URB RADIO AM/FM STEREO, SEEK/SCAN, DVD, CD, CLOCK ETR, NAVIGATION, VOICE REC AM/FM STEREO W/DVD,CD,NAV,VOICE RECOGNITION(URB)
7,691
US3 ANTENNA DIVERSITY DIVERSITY ANTENNA(US3)
26,728
UV6 DISPLAY,HEADUP HEAD UP DISPLAY(UV6)
24,028
U2K DIGITAL AUDIO SYSTEM S-BAND DIGITAL S-BAND AUDIO SYS(U2K)
14,833
U52 CLUSTER,INSTRUMENT(ELECTRONIC) ELEK GA CSTR(U52)
26,728
U65 SPEAKER SYSTEM 7,PREMIUM 7 SPKR SYSTEM,PREMIUM(U65)
24,028
VA5 LANGUAGE LABEL(ENGLISH) ENGLISH LANGUAGE LABEL(VA5)
12,892
VDD Unk. 24,214
VM3 LABEL INFORMATION CONSUMER, CONTAINS BPR IMP STANDARD FOR FRT 5 MPH & RR 5 MPH 5 MPH BUMPER INFO LABEL(VM3)
19,863
V73 VEHICLE STATEMENT - US/CANADA US/CANADA VEHICLE STATEMENT(V73)
24,981
XFV TIRE FRONT P245/40ZR18-88Y BW HW4 (EMT) TIRE(XFV)
15,796
YFX TIRE REAR P285/35ZR19-90Y BW HW4 (EMT) TIRE(YFX)
15,796
1SB PACKAGE-OPTION 02 (1SB)
SALES PACKAGE SALES PKG(1SB)
22,313
1SZ PACKAGE OPTION- (1SZ)
24,167
31I INTERIOR TRIM LT CASHMERE (04) (31I)
7,043
313 TRIM COMBINATION LEATHER, LT CASHMERE (3) (04) (313)
7,043
74U EXTERIOR COLOR,PRIMARY (74U)
EXTERIOR COLOR,PRIMARY,VICTORY RED (74U)
3,283
AAB MEMORY DRIVER CONVENIENCE PACKAGE CONVENIENCE PKG(AAB)
24,028
AG2 ADJUSTER PASS ST POWER, MULTI-DIRECTIONAL MULTI-DIRECTIONAL P/SEAT ADJR(AG2)
ADJUSTER,SEAT,6-WAY POWER,SPLIT BENCH,PASSENGER 6-WAY PWR P/SEAT ADJR(AG2)
26,129
AJ7 RESTRAINT SYSTEM FRT SEAT, INFLATABLE, DRIVER AND PASSENGER, FRT & SIDE INFL RST FRT & SI(AJ7)
26,129
AQ9 SEAT,FRONT BUCKET,DRIVER,PASSENGER,RECLINING RECL FRT BKT ST,LUXURY(AQ9)
26,129
BGR Unk. 26,728
CF7 ROOF,SUN,REMOVABLE,NON-TRANSPARENT REMOVABLE SUNROOF(CF7)
15,670
CJ2 HVAC SYSTEM AIR CONDITIONER FRT, AUTO TEMP CONT, AUX TEMP CONT A/C FRT AUTO/AUX CONT(CJ2)
26,728
DD0 MIRROR,O/S,R AND L REM CTL,ELEC,DEFOG,LT SENSITIVE O/S ELEC R/CON MIR(DD0)
24,028
DD8 MIRROR,INSIDE,REARVIEW,TILT,AUTOMATIC,LI GHT SENSITIVE I/S RR VIEW MIR,LIGHT SENSITIVE(DD8)
24,028
DL5 DECAL ROADSIDE SERVICE INFORMATION ROADSIDE SERVICE INFO DECAL(DL5)
24,214
D42 COVER,REAR COMPARTMENT SECURITY(SHADE) R/CMPT SECURITY SHADE(D42)
26,034
E2C Unk. 10,812
FE1 SUSPENSION SYSTEM,SOFT RIDE SOFT RIDE SUSP(FE1)
9,777
FE9 FEDERAL EMISSION CERTIFICATION FED EMIS(FE9)
18,711
GU6 AXLE,REAR,3.42 RATIO 3.42R(GU6)
10,997
IL3 TRIM,INTERIOR DESIGN (IL3)
26,129
JL5 CONTROL MANUAL TRANS, FIRST TO FOURTH GEAR SKIP SHIFT 1ST TO 4TH GEAR SKIP SHIFT CONTROL(JL5)
10,216
JL9 BRAKE SYSTEM,POWER,FRONT AND REAR DISC,ANTILOCK FRT & RR DISC ANTILOCK BRK(JL9)
15,250
KA1 HEATER - SEAT ST HTR(KA1)
23,804
K63 GENERATOR 110 AMP 110 AMP GEN(K63)
26,728
LS2 ENGINE,6.0L(364CID) GAS V8 6.0-H(LS2)
ENGINE,6.0L(364CID) GAS V8 6.0-U(LS2)
26,728
MM6 TRANSMISSION MAN 6 SPD, BORG WARNER, 85MM, 1ST 2.66, 6TH 0.50, O/D 6-SPD M/TRANS(MM6)
4,595
MN6 TRANSMISSION,MANUAL 6-SPEED PROVISIONS(MERCHANDISING OPTION) 6-SPD M/TRANS PROVISIONS(MN6)
10,997
NK4 STEERING WHEEL,SPORT,LEATHER SPORT WHL(NK4)
STEERING WHEEL,SPORT,LEATHER WRAPPED LEATHER WRAPPED SPORT STRG WHL(NK4)
26,728
NT9 EMISSION SYSTEM FEDERAL, TIER 2 PHASE-OUT TIER 2 PHASE-OUT FED EMIS(NT9)
18,778
N37 STEERING COLUMN,TILT AND TELESCOPING T&T WHL(N37)
22,793
QG7 WHEEL 18 X 8.5 FRT & 19 X 10 RR, POLISHED POLISHED WHL(QG7)
18,303
R9Z Unk. 8,802
SLL SOLD ORDERS SOLD ORDER(SLL)
8,676
Old Nov 23, 2010 | 01:11 AM
haljensen's Avatar
haljensen
Corvette sellers are like Pontiac Firebird sellers. Corvette has Z51 that nearly every used Corvette seems to have and Firebird sellers have the WS6 that appears to be on every firebird for sale.
Old Nov 23, 2010 | 07:48 AM
juyanith's Avatar
juyanith
Thank you Kent. That looks like what I found on comp nine's site. I was hoping that perhaps it was wrong. Oh well. I understand that mistakes happen, but it's not like it's hard for a seller to check the codes *on the car*. I guess that's why they say "caveat emptor".
Old Nov 23, 2010 | 12:14 PM
ALD_Z06's Avatar
ALD_Z06
Vehicle Information
VIN: 1G1YY24U955114845 Model: 1YY07-2005 CORVETTE COUPE
Service Contract: No Branded Title: No Warranty Block: No PDI Status: No
Order Type: 60 - RETAIL - SOLD
Field Actions: 2 Open
Vehicle Build
Model: 1YY07-2005 CORVETTE COUPE Order Number: HQSHMG
Gross Vehicle Weight: 1,665 Build Date: 01/21/2005
Build Plant: 5-
Option Codes
*GMVIS is not the definitive source of GM Vehicle RPO information and is intended for service reference only. Should there be any questions about the vehicle's original build or RPO information please refer to the original vehicle invoice or window sticker.
1SB - PREFERRED EQUIPMENT GROUP AIR BAGS, FRONTAL & SIDE IMPACT DRIVER & PASSENGER LUGGAGE SHADE & PARCEL NET 6-WAY POWER PASSENGER SEAT ADJUSTABLE SPORT BUCKET SEATS W/PERFORATED LEATHER INSERTS HEAD UP DISPLAY HOMELINK TRANSMITTER MEMORY PACKAGE AUTO DIMMING ISRV MIRROR W/COMPASS & DRIVER OSRV MIRROR HEATED SEATS RDS AM/FM STEREO W/6-DISC IN DASH CD W/MP3 PLAYBACK, BOSE PREMIUM 7 SPEAKER SYSTEM (REPLACES STD/OPT/PKG RADIO) PWR TELESCOPING STEERING 1SZ - PREFERRED EQUIPMENT SAVINGS
313 - CASHMERE LEATHER TRIM SEATING 31I - LT CASHMERE INTERIOR TRIM
74U - VICTORY RED AAB - MEMORY PACKAGE
AG2 - SIX-WAY POWER PASSENGER SEAT AJ7 - AIR BAGS, FRONTAL & SIDE IMPACT, DRIVER & PASSENGER
AQ9 - ADJUSTABLE SPORT BUCKET SEATS WITH LEATHER TRIMMED SEATING SURFACES BGR - BOWLING GREEN PLANT
CF7 - REMOVABLE ROOF PANEL CJ2 - AIR CONDITIONING-ELECTRONIC DUAL ZONE
D42 - LUGGAGE SHADE & PARCEL NET DD0 - ELECTROCHROMIC MIRRORS INSIDE REAR & LEFT OUTSIDE REAR
DD8 - OSRV DL5 - ROADSIDE SERVICE INFORMATION DECAL
E2C - ORDER TO DELIVERY - EXPEDITE FE1 - SUSPENSION SYSTEM-SOFT RIDE
FE9 - 50-STATE EMISSIONS GU6 - REAR AXLE 3.42 RATIO
IL3 - TRIM INTERIOR DESIGN-AQ9 JL5 - CONTROL MANUAL TRANS, 1ST TO 4TH GEAR SKIP SHIFT
JL9 - 4-WHEEL DISC ANTI-LOCK BRAKE SYSTEM K63 - 110 AMP GENERATOR
KA1 - HEATED SEATS LS2 - 6.0 LITER SFI V8 - 400 HP
MM6 - 6-SPEED MANUAL TRANSMISSION MN6 - 6-SPEED MANUAL TRANSMISSION
N37 - STEERING: POWER TELESCOPING& MANUAL TILT STEERING COLUMN NK4 - LEATHER WRAPPED STEERING WHEEL
NT9 - FED EMIS SYS, TIER 2 PHASE-OUT QG7 - POLISHED ALUMINUM WHEELS
R9Z - POMS EXPEDITE - SOLD ORDERS SLL - SOLD ORDERS
U2K - XM SATELLITE RADIO - OVER 130 CHNLS OF DIGITAL ENTERTAINMENT SERVICE FEE EXTRA.1ST 3MOS.INCL U52 - ELECTRONIC INSTRUMENTATION
U65 - SPEAKER SYSTEM 7, PREMIUM UE1 - ONSTAR SYSTEM INCLUDES 1 YR SAFE & SOUND
UG1 - HOMELINK TRANSMITTER UJ9 - LOW TIRE PRESS. INDICATOR
URB - AM/FM CD WITH DVD NAVIGATION, BOSE PREMIUM 7 SPEAKER SYSTEM (REPLACES STD/OPT/PKG RADIO) US3 - ANTENNA DIVERSITY
UV6 - HEAD UP DISPLAY V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA
VA5 - ENGLISH LANGUAGE LABEL VDD - VEHICLE INFORMATION DVD
VM3 - CONSUMER INFORMATION LABEL XFV - FRONT TIRE - P245/40ZR18
YFX - REAR TIRE - P285/35ZR19
Sorry, no Z51 package.
To VIS request
