Replace Tire Sensor Grommets?
Old Dec 17, 2010 | 09:37 PM
Red Rochester's Avatar
Red Rochester
Veteran: Coast Guard
CHange them
Old Dec 17, 2010 | 09:40 PM
crakavelli's Avatar
crakavelli
Thanks for the info in this thread, I have had a naggin slow leak in my passenger-side front tire. It has a really slow leak and I cannot find any screw or other defects in the tire. Recently when it dipped below 40 degrees in Houston I have been losing 8-10lbs of pressure overnight, but if it stays warm I only lose 1-2lbs. I am going to get these "grommets" checked tomorrow.
Old Dec 17, 2010 | 09:47 PM
dpigguy's Avatar
dpigguy
more than likely you have a retaining nut that is not torqued correctly. you may want to look at that before you pull sensor, etc.
Old Dec 17, 2010 | 10:09 PM
cclive's Avatar
cclive
Originally Posted by BEZ06
Hi Chris
Yeah, the avatar is just too small of a picture to be able to read the sign. I need to go out and take another one with mostly sign and just a little bit of car to see if it will be readable in the avatar.
Anyway, it's a sign right after you enter our housing development. It's sorta true - but there are actually more adults at play than kids!!!
Bob
It should have a small ZR1 on it...then we would know who is REALLY at play.
Old Dec 17, 2010 | 10:55 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Thanks to all who responded, especially Bob for the new pics.
I'll get a set to be ready for Spring!
