When downshifting, using paddle shift, my engine rev's up before it downshifts into 2nd gear. All other gears downshift w/o any rev's. My 2007 Vette did not do this. Anybody else with a 2011 Vette noticing this?
I have a 2011 GS w/paddles, does the same. It's 'Rev Matching' and pretty damn cool.
My 07 does it. I don't think rev-match shifts are anything new.
Sounds bad-*** with my Borla exhaust.
My 06 doesn't do it automatically, but there is usually enough lag time between the flick of the paddle and the actual downshift that I can rev it myself. It takes some practice and doesn't always work, but if you routinely downshift when coming to a stop, it is probably good practice to try to match revs in order to reduce wear on the driveline components.
AFAIC, rev-matching downshifts are the best feature on the new Vettes, especially with the fuse pulled on an NPP car..........
Paul
why pull the fuse when for less than $90 you can get the Mild-2-Wild NPP remote control that takes about 5 minutes to install... Wild most of the time but on the highway is Mild...
I can do this going down into 5 th 4th and 3rd but second and first is a biatch when I try this. Like you said the lag time pause in the auto gives you enough space to do a blip yourself. I have a very hard time doing any D/S to second and first.
