winterizing for cold garage
i am storing my c6 for the winter in a cold unattached garage.
so far i will....
put extra air in tires
put something under the tires
clean the whole car
use a cover
put something in the tail pipes
anything else i should do?
i have heard about releasing the clips for the top
what about the battery?
i would like the hear all ideas i dont mind putting alot of time into it to make sure my car is taken care of!
thanks!
so far i will....
clean the whole car
use a cover
thanks!
If you have electricity in the garage then hook up a Battery Tender, CTEK 3300 or similar battery "maintainer", not trickle charger. If no electricity available then disconnect neg battery cable. If you do that you will have to re-index the windows when you hook it up again in Spring.
Appropriate amount of StaBil in the gas tank and preferably drive for 20-30 minutes to distribute it through the lines.
Change the oil and filter. Don't want to leave dirty oil in the engine for several months. Again, drive a few minutes if possible.
Ideas for mouse repellent:
http://forums.corvetteforum.com/c6-c...-vehicles.html
St. Jude Donor '15
"In honor of jpee"
Airing up the tires is unnecessary. That's old school thinking that dates back to bias-ply tires.
I have never used Stabil in anything I own. This will be the first year for the Vette(new owner), so we'll see how it works out. My boat always gets a fill up with fresh gas just prior to parking it for the winter. That sucker sits for 7 months of the year in my neck of the woods, and I've never encountered a single fuel-related issue in the spring despite the lack of a fuel stabilizer.
Basically, I cleaned the car, changed the oil, hooked up a battery maintainer, covered it with a quality cover, and put it to bed until late-April/early-May. We'll see how things pan out in 4 1/2 months.........
Paul
Paul
Paul
Paul
http://www.fuel-testers.com/ethanol_...ecautions.html
Nope. My mind's made up.
Of course, it might help that I am able to avoid the use of ethanol-blended fuels. Oh Canada.........!!!!!!
By the way, the only "old school thinking" I referred to was airing up radial tires for the winter, but it was kind of you to quote me out of context. Should I provide you with a link to prove I'm right about the tire thing??????
Paul
Paul
St. Jude Donor '15
"In honor of jpee"
Warmer humid air and a colder car = condensation.
Is it a big problem? No. Is it easy to address? Yes.
You might want to consider inserting a pad of steel wool in each to prevent rodents from chewing through to gain entry into your exhaust system. I use it in my house to plug holes where water pipes etc enter the house and it works well.
Any body have any experience with those electronic rodent repellers?
They plug into an available outlet and emit a sonic pulse about every 5 seconds to scare the little bastiches away. I have a couple in the Vette's stall but think I will try the mothball thing too!
oh yea, that's if you back your car in like I do.
