C6 hud wtf?
Received 2,051 Likes
St. Jude Donor '13
If he hasn't already, OP needs to try setting the HUD on full bright and then use the up/down switch to see if he can make it visible. If he can, then set the #1 memory that way. Then, set the #2 memory that way also unless a second driver needs it to be positioned slightly differently.
Keeping our fingers crossed...
St. Jude Donor '08-'09-'10-'11-'12
No need to get angry Fuse box, behind passenger footwell, see Owners Manual, pg 5-89. Its the fuse labeled "Cluster, Heads-Up Display".
I've had my '05 for 2 months now...the HUD will light up, go up and down in brightness and BEGIN to raise, but will quickly slam back down out of sight....I can see it illuminated on the glass, but the actual image is facing down, and will only come up for a second. does this sound like the pins/supports are broken?
1. With the engine running, press/hold the '+' button awhile to get max brightness.
2. Hold the '^' up-arrow, then hold the 'v' down-arrow -- that is, cycle thru range of adjustment until you see the HUD display.
3. It sounds like your HUD is making automatic adjustments to hide the display. This might've been the previous owner's preference... you'll need to change the fob memory settings:
DIC Vehicle Personalization
Many features on your vehicle can be personalized.
This means that the operation of these features can be
set to operate differently depending on who is driving
the vehicle. See “Personal Options” later in this section
for the features that you can personalize.
The personalization settings for other features are
automatically updated and saved as the driver adjusts
them. These include the following settings and presets:
• The radio presets, tone, volume, fade, balance,
equalization (EQ) settings and source (radio or CD)
• The last climate control setting
• The Head-Up Display (HUD) position and dimming
level, if your vehicle has this feature
• The instrument panel cluster dimming level and last
selected DIC display
Separate personalization settings are saved for
two different drivers. One of the keyless access
transmitters is assigned to driver 1. The other is
assigned to driver 2. The back of the keyless access
transmitters are labelled 1 or 2 to correspond to each
driver.
driver.
4. Day and night settings can be different: http://forums.corvetteforum.com/c6-c...d-experts.html
Last edited by CO Lightfoot; 12-23-2010 at 02:05 PM. Reason: add link for online owners manual
Might actually be working properly.
See your owners manual for more details: http://www.gmpartshouse.com/download...05corvette.pdf
Okay, that works...to a point...
If i HOLD DOWN the up arrow to adjust the height it will fall back down...is it supposed to do that?
I have to bump it up one notch at a time, careful not to go too far or it will fall back down and I have to reset the whole unit by holding the down arrow for three seconds till it clicks and then go back up with it....something tells me that, while mine "works", that's not the intended design to just plummet back into the dash if you hold down the up arrow
Norskie (09-05-2016)
St. Jude Donor '13
You are correct, sounds like something is broken.
Good luck with a cheap and effective repair.
My HUD Reflector pivot also failed. The pivot side (opposite the gear and motor) is a VERY poorly designed thin plastic piece. IMHO, this should have been a powdered metal part or a thicker more rugged plastic. Spent a good 14 hours removing and replacing dash/HUD. I purchased a used unit and checked the pivot and it also was ready to go so beware if you purchase a used unit. I modified the mount point of the reflector pivot with some .015 spring steel that I had in the garage. This is where the HUD reflector will fail and with this side broken the opposite side will also break rendering the HUD unusuable.
I went without my HUD for a couple of months and I'm happy that it's fixed again.
What instructions did you follow for removal and access to the HUD?
http://www.theredlion.us/C6%20HUD%20...%20Rev%202.pdf
http://forums.corvetteforum.com/c6-c...d-install.html
Mr.Fixzit (09-04-2016)
I think my mount is also broken, because I would come out some mornings and my display would be way up too high, or too low. I adjusted back to my preference several times, and then yesterday it just went crazy, every time I put on the brakes, the display would whoosh! right off the windshield like it was taking off for flight. Today, there is no display at all, but I see a mirror-like reflection in my windshield which is now driving me crazy. I think whatever bracket that was holding the mirror has broken and the mirror has fallen down and is now reflecting off the windshield. Can this be repaired? Do I need a new HUD? Agh, this is very frustrating. This sounds like it is happening to a lot of people and my extended warranty just expired of course.
#33
Here's the reference that I used:
#34
You know this post is 5 years old ...?
#36
Received 3,629 Likes
2016 C6 of Year Finalist
#37
It took a long time but mine is going bad now - in 2021
Yes, this thread is still germaine. My 06 has 107,000 miles on it and the HUD just started to bounce a little. I have read all the threads on this subject and will tackle this one over the winter.
Thanks to all who are still with us.
Paul
Paul
#38
Fixed mine last night. Here's a tip on cutting the ac duct. Get one of those razor knives that has the blade you can break off the tip and run it out about 2" or so and heat it with a touch and it will cut like butter.
#39
C6 HUD not displaying fix
[Omg, i have a 2010; battery was run dead b/c I didn't realize I'd legt the accessory on when I turned push button off. I noticed some time later (days later after recharging the battery), the HUD no longer displaying. Saw this post, and I reset the memory buttons on the seats and it fixed it!!!! Thank you so much!!!
QUOTE=Gearhead Jim;1576285768]Yes, the HUD position can be controlled by the memory system.
Keeping our fingers crossed...[/QUOTE]
