Locked out
Old Dec 21, 2010 | 08:09 AM
ben dover's Avatar
ben dover
From: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05 thru '26
Originally Posted by 6speedC6
Call On Star, tell them honestly your car is locked, can they sign you up and than unlock your car!!! may be cheaper than a locksmith
1 month service will be the cheapest way in.
Old Dec 26, 2010 | 12:21 AM
hunter4's Avatar
hunter4
2nd Gear
How do you get in a locked 2009 Z06 when the car battery is dead?
Old Dec 26, 2010 | 12:42 AM
Vette_DD's Avatar
Vette_DD
Use the key in the fob to unlock the back hatch. Once inside the back hatch area, pull the tag on the driver's side over the rear wheel that's labeled for the door. Pulling on it will open the driver's door.
I've forgotten, where is the battery located in the Z06?
It's explained in the owner's manual.
Old Dec 26, 2010 | 12:51 AM
hunter4's Avatar
hunter4
2nd Gear
Thanks, I didn't know there was a key in the fob.
Old Dec 26, 2010 | 01:03 AM
Vette_DD's Avatar
Vette_DD
Sorry, I should have also mentioned that the keyhole is above the license plate. It is hard to find.
Old Dec 26, 2010 | 09:53 AM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
The only time your girl should climb out the window is if she is wearing a short skirt. Well, that's what I would see as a good event. Otherwise, the handle on the floor is probably your best option!
Elmer
Old Dec 26, 2010 | 12:52 PM
StKnoWhere's Avatar
StKnoWhere
Ummm, how can you activate Onstar if you're not in the car?
Old Dec 26, 2010 | 12:59 PM
timd38's Avatar
timd38
They have a number you call along with a passcode. I guess if you can't keep track of your keys, why would you keep track of the passcode.
Old Dec 26, 2010 | 01:11 PM
StKnoWhere's Avatar
StKnoWhere
Apologies for the temporary thread hijack, but is there a way to find out your passcode if you bought a used car?
Old Dec 26, 2010 | 01:45 PM
timd38's Avatar
timd38
You will need to buy a subscription. I would start with this black looking book called an "owners manual", and it should walk you through how to buy a subscription.
Old Dec 26, 2010 | 01:58 PM
andy82's Avatar
andy82
2017 C7 of Year Finalist
Originally Posted by Big JL
I'm wondering if they may be in the trunk... If they were, would the fob range be sufficient enough to be unlocking the doors?
JL
Absolutely not! Happened to me twice and my daughter had to come and bring me the key because nobody will even try to open that car (e.g AAA) without the garantee for no damage.
Old Jan 1, 2011 | 10:53 PM
lifter213's Avatar
lifter213
I bought my 09 C6 used in September and it only came with one fob and I'm ashamed to say I locked it into the trunk a few months ago. I had just finished playing softball and my fob was in my backpack when I opened the trunk by pressing the button by the plate. Opened the hatch, put backpack in and closed right as I realized what I did. Called OnStar gave them my VIN but they wouldn't sign me up on the phone, said i had to hit the button in the inside to signup. So they transfered me to roadside assistance who then called a locksmith for me. He was able to put the plastic stick in through the passenger side window and release the emergency pull on the floorboard. Granted it took awhile 30 minutes of trying but it was done.
I've since made two copies of the key, one hidden on the car and the other spare at home. I still need to buy another fob though.
Old Jan 1, 2011 | 11:09 PM
  #33
Knob Jockey's Avatar
Knob Jockey
St. Jude Donor '11-'12-'13-'14-'15
Glad you were able to find a clever/experienced locksmith.
As long as you're buying another fob, buy two. You can program up to four for the car.
Then hide fob #3 somewhere in the car and if you lose your fob while you're out and about you can still get in using your hidden key and start/drive the car with the hidden fob.
Old Jan 2, 2011 | 10:46 AM
  #34
z51vett's Avatar
z51vett
I'm traveling and have lost track of the vette keys. I'm wondering if they may be in the trunk... If they were, would the fob range be sufficient enough to be unlocking the doors? Obviously the doors are not unlocking, so if the range is sufficient I can rule the trunk out as possible places they could be.
On another note, how do you get into these cars without a fob or key? Given the electronic locks, I wouldn't know where to begin.
Thanks all for your help, and Merry Christmas.
JL
Call Gm roadside asst. if you still have coverage they will send out lock smith with key to unlock rear hatch. Them you pull the release wire drive side their are 2 one gas door the other opens drivers door.This will get you into car if you have no fobs you will need to buy one and have program it. 1-800-222-1020 for chev they will put you in contact with roadside asst.
z51vett
Old Jan 2, 2011 | 01:48 PM
  #35
JoesC5's Avatar
JoesC5
About 8-9 months after I purchased my 98 C5, GM send me a (FREE)special flat key in a plastic sleeve that was made to fit in your wallet(and cut to fit my VIN). The key would extend out the end of the sleeve and the sleeve gave you the width needed to leverage the lock. I guess that GM figured I was dumb enough to lock my keys in the car. Since I now had the spare key in my wallet, I found it was never necessary for me to use it.
When I purchased my C6Z, the first thing I did was to have a locksmith cut me two keys using a Saturn B-106 blank(no thick plastic handle) and I keep one in my wallet and the other is hid on the car. $6.40 for two keys is cheap insurance to never have to mess with the trials and tribulations of locking myself out of my car.
Old Jan 2, 2011 | 06:46 PM
  #36
haljensen's Avatar
haljensen
Every time I read one of these "I'm locked out of my car, what do I do?" threads (every day?) I wonder if anybody ever reads their Owners Manual.
The solution is simple; DISABLE THE PASSIVE LOCKING! That way the only time the doors and hatch will lock is when you press the lock symbol on the fob. I think the passive locking is great idea, my fob stays in my left pocket all the time, no need to ever press any buttons.
On my '08 the passive locking is explained on page 3-77.
