Beeps from DIC
Old Dec 24, 2010 | 01:37 AM
rowdymax's Avatar
rowdymax
Default Beeps from DIC
I am getting constant beeps from the DIC, but nothing shows up in the DIC??? It's the same beep that you get when you push DIC buttons...Any have this issue and know what the problem is???
Thanks in advance...
Old Dec 24, 2010 | 05:02 AM
foremaw's Avatar
foremaw
Active Streak: 90 Days
St. Jude Donor '08-'09-'10-'11-'12
Sounds like one of the buttons is stuck or damaged. What happens when you run through all the guage/option buttons to the right of the instrument cluster? Do they all work right?
Old Dec 24, 2010 | 07:51 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Or one of those buttons is stuck
Old Dec 24, 2010 | 10:02 AM
rowdymax's Avatar
rowdymax
That's what i thought, but it doesn't happen all the time...Yes, all the buttons work and they beep when pressed...It has a mind of it's own and just beeps at different times and sometimes like yesterday, beeped off and on for 10 minutes????
Old Dec 24, 2010 | 11:38 AM
StKnoWhere's Avatar
StKnoWhere
Very sorry for mentioning the obvious, but if you have them, did you check the seat memory buttons also?
Old Dec 27, 2010 | 04:27 PM
Corby's Avatar
Corby
Mine beeps if the E-brake is not off fully.
Old Aug 16, 2015 | 11:05 AM
shleevo's Avatar
shleevo
Anyone here find a solution to this problem? I have the exact same issue on a 2011 GS with memory seats. GM replaced the memory seat switch in the door but didn't fix the problem. Issue has been on going for a few years. I will check the parking brake next.
To Beeps from DIC
