Traction Control question
Old Dec 29, 2010 | 10:20 AM
ninjabob86's Avatar
ninjabob86
Default Traction Control question
It’s cold here in Ohio but I’ve had to drive the Vette a couple of times lately. On two occasions the back end has broken loose violently to the right while accelerating, once on cold dry pavement medium throttle in second and the other on cold wet pavement, medium throttle in third. Both times the rpm was going past 3500 which is the beginning of serious HP, even on the “baby” LS3. The traction control was ON and I guess I expected a gentler transition to an out-of-control condition. Is this an indication of a problem? There are no errors on the DIC.
Old Dec 29, 2010 | 10:29 AM
Vivid1's Avatar
Vivid1
nope. no problem at all. Cold tires and cold pavement with salt will definitely make it easier to get squirly.
Old Dec 29, 2010 | 10:38 AM
dvilin's Avatar
dvilin
That is about as gentle as it gets, just think of how the car would react without TC. I do not think you have any problems with your system. From my experience what you describe is normal.
Old Dec 29, 2010 | 10:56 AM
Vette5.5's Avatar
Vette5.5
Believe it or not, there's intentionally some wheel spin dialed into the TC system for safety reason's. My C5 would allow absolutely no wheel spin at all. When pulling out into traffic on loose pavement the car just flat out died, and almost got rear ended a few time's. Think GM know's what they're doing on the newer system's.
Old Dec 29, 2010 | 11:00 AM
Wayne O's Avatar
Wayne O
CF Senior Member
Consider it a safety warning. Cold temperatures, cold pavement couple with cold tires are a recipe for disaster. I doubt anything is wrong with your car...traction control is not a fail safe. Instead of medium throttle I suggest low throttle and use extreme care until you get a feel for how conditions are. Just putting around on the street you're not going to put much heat into your tires. When conditions are iffy I like to get in a safe place and test the car...give it some gas, maybe stab the brakes, turn sharply and see what happens. Get a feel for conditions before they catch you off guard and something really bad happens.
About a month ago I was on my out lap just turning onto the road course at Phoenix International Raceway (with racing slicks, traction control off). It was 8AM with a temperature of 29 degrees. I knew to be careful. Just turning onto the track I spun my car around like it was on ice. I felt like an idiot but I watched the video later...I did not give the car much gas at all (but still driver error). Despite being careful it happend. It was a wake-up call for me...I was very cautious the rest of the day.
Old Dec 29, 2010 | 11:02 AM
gilhuly's Avatar
gilhuly
mine did the same thing comin' outa the car wash. cold road,wet tires,tail waggin fun,let off the gas, do it again.
Old Dec 29, 2010 | 11:03 AM
goatts's Avatar
goatts
I agree. Same for AH. If you're determined to get yourself in trouble, you still can.
Old Dec 29, 2010 | 12:09 PM
Dif's Avatar
Dif
I presume the only real problem is you're running Summer tires in cold weather.
Aside from the road conditions being Cold, regardless of wet or dry,.. the tires are also Cold.
When the tires are cold they get like Hocky pucks
Personally, I start noticing loss of traction anytime the temperature drops below 40.
I can imagine how much worse it is near or below 30.
IMO, Caution is the order of the day
Old Dec 29, 2010 | 12:34 PM
Joz132's Avatar
Joz132
St. Jude Donor '12-'13
Nothing wrong - the group is correct.
Any performance tire that is pushed aggressively on a cold day can bite you. Ask me how i know...
Old Dec 29, 2010 | 12:36 PM
boraxman's Avatar
boraxman
^^^^^ ouch!!!
To Traction Control question
