Nitrogen Question
Some people swear by it, and won't let you put anything else in their tires. Personally, I think they drank the koolaid.
In theory, since nitrogen molecules are bigger than oxygen or other molecules that make up the air, and thus harder to get out through teeny tiny little seams in the tires and around the bead, filling a tire with them should keep pressure up longer.
Note, the key word above is longer. It still seeps out, maybe just not as quickly. I never bought into the nitrogen thing for several reasons:
1) It costs about $25 or so to have all the bad air sucked out and have nitrogen put back in. Maybe I'm just a cheapskate, but for the price of 25 McChiken sandwiches, I always thought it was more marketing than actual value.
2) You still have to put the stuff back in from time to time. And, you can't do it down at the local Gas & Grunt. You have to go somewhere where they actually have nitrogen.
3) You should be checking your tires for tread depth, wear patterns and pressure regularly anyway. TPM's probably contribute to more tire wear than they save, because when people have TPM's they tend to forget about their tires and how they are wearing and think that as long as the light is off, all's good on the corners.
4) Air is about 78% or so nitrogen anyway. I don't know what that has to do with anything, but to pay to get that up to about the 90% level, which is what you actually get, just wasn't anything I could get excited about.
From my experience on the service drive, I think people do it because it makes them "feel" better. Kind of like changing their oil more often than the manufacturer recommends. Do it if you want. I'll pass.
Nitrogen does not expand or contract nearly as much as regular atmosphere. That is part of why it is in every rifle-scope you will buy. It also prevents fogging up under temp-changes (not really important for a tire).
But yes, using nitrogen lessens the effect of temperature changes on the tire pressure which would change the contact patch.
Did a word seach for "nitrogen" in the 2008 owner's manual-- zero hits. The owner's manual does recommend inflating the tires with "air" (p. 5-67).
Googled "air." Based on the results, for my tires, I have decided to go with a precise mixture of the following:
Nitrogen N2 78.084 %
Oxygen O2 20.9476 %
Argon Ar 0.934 %
Carbon Dioxide CO2 0.0314 %
Neon Ne 0.001818 %
Methane CH4 0.0002 %
Helium He 0.000524 %
Krypton Kr 0.000114 %
Hydrogen H2 0.00005 %
Xenon Xe 0.0000087 %
To my delight and joy, I also discovered that this mixture is readily available and typically less expensive than nitrogen servicing.
Her car reminded me that maybe I should get nitrogen in my tires. It was my understanding that nitrogen filled tires will maintain pressure regardless of the temperature and this would be nice for me.
She got a low tire pressure warning on her car and took it in. They added nitrogen and she brought up what I had told her about tire pressure with nitrogen in them not fluctuating. The guy at the dealership says that pressure will still change some with very cold weather.
So, what is the real story?
First, an N2 molecule is almost exactly the same size as an O2 molecule, at ~300 picometers versus ~292 picometers in length (if you simply calculate based on covalent radii.) If you use the covalent radius for N2 with a triple bond, then you wind up with a length of about 216 picometers, and with a covalent radius for O2 with a double bond, you wind up with a length of about 228 picometers, meaning that O2 is actually larger.
Somehow I doubt that a mounted tire has a problem with one leaking out but not the other.
N2 is used in aviation, but that's because aircraft tires encounter much greater changes in temperature and pressure.
Water vapor in your tire can result in larger pressure fluctuations as it heats up, but that's easily counteracted by simply filling your tire up with dry air. As any A/C unit dries the air, if you find yourself in a humid environment and care that much, simply air up your tire inside your house, or with your air compressor drawing air from inside your car while the A/C is running and the air is dry.
When you purchase compressed nitrogen, you are buying Nitrogen with trace inerts, having a purity 99.998% with Oxygen Less than 0.001%
Nuff said!
Had to spend half the night trying to figure out how to measure what the hell a picometer is/are. At first I thought it had something to do with picking my nose...but that wasn't it.
Then came the covalent issue.............
Finally had to quit when it came to water vapor thing..........
add: the air we breathe (room air) is vast majority nitrogen anyway....so why pay more money????
WRONG!!!!! I think you have Helium confused with hydrogen. But you will need to look it up to confirm my statement.
"HELIUM IS NOT FLAMMABLE"
HELIUM
