My wife's new Buick Enclave came with a window sticker indicating it has nitrogen in the tires. Our temperature here in Arkansas fluctuates and I am often adding air or removing it from my vette tires to keep the air pressure right.
Her car reminded me that maybe I should get nitrogen in my tires. It was my understanding that nitrogen filled tires will maintain pressure regardless of the temperature and this would be nice for me.
She got a low tire pressure warning on her car and took it in. They added nitrogen and she brought up what I had told her about tire pressure with nitrogen in them not fluctuating. The guy at the dealership says that pressure will still change some with very cold weather.
Oh boy, I LOVE nitrogen questions. I was once a service advisor and was heavily involved in the process and marketing when we added nitrogen service in the shop.
Some people swear by it, and won't let you put anything else in their tires. Personally, I think they drank the koolaid.
In theory, since nitrogen molecules are bigger than oxygen or other molecules that make up the air, and thus harder to get out through teeny tiny little seams in the tires and around the bead, filling a tire with them should keep pressure up longer.
Note, the key word above is longer. It still seeps out, maybe just not as quickly. I never bought into the nitrogen thing for several reasons:
1) It costs about $25 or so to have all the bad air sucked out and have nitrogen put back in. Maybe I'm just a cheapskate, but for the price of 25 McChiken sandwiches, I always thought it was more marketing than actual value.
2) You still have to put the stuff back in from time to time. And, you can't do it down at the local Gas & Grunt. You have to go somewhere where they actually have nitrogen.
3) You should be checking your tires for tread depth, wear patterns and pressure regularly anyway. TPM's probably contribute to more tire wear than they save, because when people have TPM's they tend to forget about their tires and how they are wearing and think that as long as the light is off, all's good on the corners.
4) Air is about 78% or so nitrogen anyway. I don't know what that has to do with anything, but to pay to get that up to about the 90% level, which is what you actually get, just wasn't anything I could get excited about.
From my experience on the service drive, I think people do it because it makes them "feel" better. Kind of like changing their oil more often than the manufacturer recommends. Do it if you want. I'll pass.
Thanks for the replies guys. If it would make a difference in tire pressure changes with temperature I'd get it but it seems that there is no real advantage.
Right. It still has to obey the laws of physics. When the outside temperature goes down, the pressure in the tire goes down. No way to get around that.
Issue is with the moisture in air. More moisture in the air, the more the pressure will change with temp. If you are familar with compressors you know how much moisture/condensation can be forced into a tire when it is inflated. Nit is extremely dry compared to air, so the pressure will change less with the temp. Simply deflating the tire and filling with nit helps, but to be really effective you need to purge (inflate/deflate) the tire a couple of times to dilute the remaining air. It is not an issue of nit staying in the tire longer, just keeping the pressure more constant. On a side note, recommended tire pressure is with the tire cold, taking into account the fact the pressure will increase about 4 lbs when warm to normal driving pressure. You will need to inflate the tire a few pounds over cold recommended pressure since the nit will not vary like the air. If you think this is bunk, ask why race teams use nit instead of air when a 1/2 lb change is critical? Is it worth it for normal driving, would say no way.
From: Stafford VA, home of our wolf den. No house break ins to date.
Before i retired from my tire guru job with the Govt... we got pushed into doing plenty of testing and cost analysis runs for nitrogen conversion of the Govt fleet.........
know what the answer was?
Its good stuff for professional car racing, and even serious amature track folks... but for all around use................. naaaaaaaaaah. you just can't monitor it the way it should be done.
From: "No matter where you go... there you are"...."You cannot drive a dollar bill". ...and remember... "D
I have to agree with Snowman and Wolfdog here and they are both right on
....Now having just said that, I use the Nitrogen in my Z ...........
....Why?....well it originally cost me 15.00 to do the procedure at my local...and close by Costco... plus where I live the local gas stations charge for air....(I also have my own air compressor jsut in case)
...but to put it simply...it is just plain quick and easy...plus they do the work.....
Oxygen molecules are in fact slightly larger not smaller than Nitrogen with a molecular weight of 16 vs 14 for Nitrogen, Unless you experience dry rot I do not see this as necessary
Absolutely NOT true. Molecular weight DOES NOT equal molecular size. Sorry, but got WAY too much brain damage in chemistry and physics classes to let this one go unchallenged.
Had issues with it, got my tires at Costco they use nitrogen with there built gauge...it was 4 lbs different then my TPS sensors..the weather got cold and I kept getting a low pressure warning. Finally I went back and had them add 4 lbs problem solved. I really need to start watching and pull out the trusty MAC tire gauge and check it once an awhile
Nitrogen is oxygen with the moisture removed. Eventually you will have to add "something" and air is free.
Well maybe not quite free. Costs me $1.50 at my local station. Actually 75 cents but I can never get all 4 tires topped off before the damn thing shuts off. Hence the other 75 cents.
Yes, I do have a small compressor at home. Takes too long to put 3-4 lbs in each tire with it.
