Yes, some jeans will bleed the blue dye. My wife had a pair that did this on the cashmere interior and her knee would rub on the door handle leaving blue dye marks. It came off with water or a interior cleaner. Since, she changed brand of jeans. Not a GM issue nor a big deal.
I had the issue with my Titanium seat in my vert after barely 2 months. Faded jeans, washed many times, still transferred blue to the seat bottom outside bolster. Tried Zaino leather cleaner, took out some but not all, still looked faint blue. Had to have it professionally cleaned/stripped and re-coated. I haven't worn jeans in the car since then.
I guess some jeans transfer, some don't.
I guess some jeans transfer, some don't. Maybe some of you guys just have too hot an ***...
Been using the Zaino leather products for years now and it cleans right up.
Recently got a new black jeans jacket I hadn't washed yet. Zaino took care of that too. Not an issue for me.
This is a $60K car. If it were a Chevy Aveo I would just deal with it.
Your jeans are transfering the dye to the seat. Other types of materials don't do this so it's definitely your jeans which have a dye that runs. If you wash them with whites I'll bet they would stain the whites. But I guess that too would be the fault of the whites so you would contact say Fruit of the Loom and tell them they have an issue becasue their white t-shirts sucked up the blue dye from your jeans.
I see now, sure it is GM's problem not your jeans...............
I have had no blue jean transfer as OP describes, but I wear well worn rags! My cashmere seats will show normal soiling but I find they are easily cleaned.
Yes, same problem here. It will continue to happen as long as you wear newer jeans. Wear faded jeans and the problem will not happen or be as bad. No need to replace the seat cover as it will happen again.
Just clean what you have.
Based on my experience with the Cashmere interior in my 2006 Coupe.
i would just clean it and then take a bath towel folded in half and put that on the seat. no more transfer and when you're not wearing jeans you can put the towel behind the seat.
