Battery Replacement Question
Old Feb 1, 2011 | 08:37 PM
Dave Tracy's Avatar
Dave Tracy
Default Battery Replacement Question
After 6 years my original battery is giving up. I have a 2005 coupe. The terminals have a threaded stud with a metric nut holding a small metal plate. The plate holds the two side of the terminal together. On the non stud terminal end there is a bent over tab from the terminal through this small plate. It would appear that this tab has to be straightened to remove the terminal. Before doing so, I wanted to check this great brain trust of information to confirm this prior to proceeding. Thank you all in advance
Old Feb 1, 2011 | 09:01 PM
EVRose's Avatar
EVRose
Just loosen the nut on top. Don't take it all the way off. Just loosen it and the terminal will come off with a twist or two. You don't need to do anything with that tab thing.
Old Feb 1, 2011 | 09:15 PM
SpryGeezer's Avatar
SpryGeezer
http://forums.corvetteforum.com/c6-c...clamp-nut.html
http://forums.corvetteforum.com/c6-c...t-inquiry.html
Old Feb 2, 2011 | 12:58 AM
Dave Tracy's Avatar
Dave Tracy
Thank you you two-I'll give it a try tomorrow.
Dave
Old Feb 2, 2011 | 01:25 AM
CO Lightfoot's Avatar
CO Lightfoot
Originally Posted by EVRose
Just loosen the nut on top. Don't take it all the way off...
Excellent advice!
Some folks remove that cone-shaped nut and lose it. Unfortunately it's a unique item that's not available separately... you have to buy the whole cable assembly -- something like $190.
Old Feb 2, 2011 | 07:14 AM
Gman in NC's Avatar
Gman in NC
Just replaced mine after six years also. Very easy to do. Make sure you get the correct battery for an '05', an '06' and newer will not fit. The terminals were reversed after '05'. I put another AC Delco back into mine ($106). Why not, when we got that much time from the original one.
To Battery Replacement Question
