Trunk lid pull down handle
I didn't like hooking my finger in the 2009 center latch to start the trunk closed, worried that I'd get my finger stuck and slam the lid on the finger. But after a few weeks, it felt natural and I don't miss the handle at all. The latch is a bit easier to use because it's in the middle, no need to move to the right side of the car.
Also, I painted the rear edge of the latch white; and put strips of white tape on the inside of the trunk lid along each side of the latch- much easier to find it in the dark.
saw a thread here on the CF a while back about a C6 owner that cracked the upper back fiberglass panel when closing the hatch with some force in colder weather...the pics of the damage were ugly !
you are left having to use the center latching "loop" opening that faces the side and seems more likley to "trap" your fingers if you get in a hurry or not paying attention compared to the original where its more natural faster/ easier movement to pull your hand straight back??
So with this logic, if someone cant get their fingers out of the latch fast enough and damages their fingers/ hand they can sue GM for same reason, now GM has to eliminate that part too?
next step: full power closing with internal latching mechanism?? =Higher cost
i think when installed they look like a tacky afterthought
Bill
https://picasaweb.google.com/Karman1...atchLidHandle#
I actually pull the lid down slowly until about 4 inches from being closed and then just press the top of the lid until the auto close grabs it and locks it. No need to slam it shut.
...still have yours lying around?
I have the shell/frame of the manual latch, and I have the striker that you'd need to swap out.
I have sold the guts of the manual latch, and I also sold the key lock cylinder/release cable that is different between the two latches.
It's not a plug-n-play operation. The two latches use different strikers (the part on the bottom of the lift gate that goes into the latch). Also, the key lock cylinders are different - the manual one has wires from it that the auto one doesn't, and the cables are different lengths.
Here's a link to a thread where I have some info on putting the auto pull down latch into my 2006 Z06. You need to scroll down to post# 44 to get to where I actually got parts and started doing the installation:
http://forums.corvetteforum.com/c6-z...ear-hatch.html
You can see that in addition to just swapping out the latch, I had to swap the striker, the key lock cylinder and release cable, and I had to rig that jumper cable in the fuse/relay/circuit breaker panel in the passenger footwell because the auto pull down latch apparently has the release relay internally mounted in the latch.
I also had to run a power wire because the manual latch only requires power when you push a button to release the latch, but the auto latch requires it all the time to provide power to the pull down solenoid.
If you go in the opposite direction to install a manual latch in a car that has the auto pull down latch, you'll need to add that release relay into the panel. Beyond that, I can't remember what electrical stuff you'd have to do.
So....I don't have any parts to speak of except the striker.
If you get into the project and have any questions, give me a holler!!
Bob
Now I use it all the time and love it.
