traction control
Old Apr 7, 2011 | 04:06 PM
GRG's Avatar
GRG
Default traction control
So if you are drag racing (on an approved track of course), you should turn the traction control off?? I don't understand, seems like you would leave it on to get traction. Please enlighten me.
Old Apr 7, 2011 | 04:22 PM
Bill Dearborn's Avatar
Bill Dearborn
When drag racing you need to spin the tires some to get maximum traction and to get the car moving. Traction control is designed to limit tire slip and it doesn't know if you are on ice, dirt or dry asphalt. In a straight line it will allow more slip as long as both tires are slipping the same. It will react very quickly though if one tire slips differently than the other. It will first cut torque and if that doesn't reduce the slippage it will apply one or both of the rear brakes to control the slip. Not exactly conducive to drag racing.
Bill
Old Apr 7, 2011 | 04:28 PM
Larry/car's Avatar
Larry/car
You have to feel your car and apply enough power to bring the tires up to the slip point without actually spinning, loosing traction. You don't just stomp on the power and hang on.
Old Apr 7, 2011 | 04:39 PM
Goatdad's Avatar
Goatdad
St. Jude Donor '11-'12-'13
Some people are quicker with it on but if you have any experience you will be quicker with it off and allowing a little slip of the tires. Try both at the track and go from there.
Practice,practice,practice
Old Apr 7, 2011 | 04:49 PM
dvilin's Avatar
dvilin
Bill
Old Apr 7, 2011 | 08:53 PM
samsiam's Avatar
samsiam
Bill
new ride coming and every now and then I just want to spin the tires on my automatic. So which way is best, traction on or off, or will it spin at all???????????
Old Apr 7, 2011 | 09:04 PM
CETA 256's Avatar
CETA 256
Are you kidding? It will roast the tires with the traction control off, but that gets expensive quickly.
Old Apr 7, 2011 | 09:13 PM
samsiam's Avatar
samsiam
Super! Can't wait. Last Vette I had when I floored it felt like the engine raised up and we took off like a rocket but it wouldn't spin the tires.
Old Apr 7, 2011 | 10:03 PM
CO Lightfoot's Avatar
CO Lightfoot
Originally Posted by Larry/car
...You don't just stomp on the power and hang on.
Actually, you do... if you engage Launch Control -- which is a standard feature of manual transmission 2010-and-newer C6's.
Edit: Never mind, just read the OP's profile... he has a 2007.
Old Apr 7, 2011 | 10:16 PM
LarryMJones's Avatar
LarryMJones
Veteran: National Guard
St. Jude Donor '13-'14-'15-'16-'17
I turn mine off.
At the track we were on last Saturday they put something down that made it like glue. No noticeable wheel spin at all with a 1500 rpm launch in a C6 auto.
On the street with less traction it is a different story.
LJ
Old Apr 7, 2011 | 10:48 PM
okie08vette's Avatar
okie08vette
I put my '08' with A6 tranny in comp mode leave the tranny in D and stomp it and hold on, best time is 12.8@113. I am thinking I should put the tranny in sport mode but not use the paddle shifter's.
Old Apr 7, 2011 | 11:53 PM
Wayne O's Avatar
Wayne O
CF Senior Member
I always shutoff TC when going WOT...I don't want the system fighting my efforts to accelerate. If I need to feather the throttle I will. I suggest using comp mode.
Old Apr 8, 2011 | 12:04 AM
Vette5.5's Avatar
Vette5.5
My car's a ZO6, and can tell you traction control will cut power way down if needed. Recall giving a demo ride, and flat out died from a light. Turned off T/C and was much more fun. Unless it's raining, T/C is alway's off, on my daily Pontiac, too.
To traction control
