Engine Coolant
The car will have to be high idled or better yet driven for say an hour - WITH THE PASSENGER HEATER ON FULL HOT AND HIGH - to fully circulate the coolant throughout the engine and heating system.
The factory uses plain tap water w/Dex-Cool went filling up the cooling system on all of their vehicles. Dex-Cool neutralizes most of the minerals in tap water (I think this is in the owner's manual).
Personally, I have the dealer use a machine (Wynn's or BG or other brand) for a complete flush with a cleaner & a conditioner with Prestone Dex-Cool 50/50...$129.95, Then I add one bottle of Red Line Water Wetter for corrosion protection.
I like the idea of adding a little extra layer to provide rust and corrosion protection.....and maybe lower my temp a little in the process. Sounds like a win-win.
what do u thinks
The Corvette is different in the plastic jug where you can add coolant is pressurized all the time, just like the rest of the system. It is called a 'surge' tank in a system like this. Coolant circulates thru it all the time, and as I said it is pressurized the same as the rest of the system. A coolant recovery tank is not pressurized.
The heater core does not have a cutoff valve. Coolant circulates all the time thru it. There is no need to 'turn the heater on'.
Buy 50/50 coolant mix, or buy 100% coolant and a jug of distilled water and mix it to a 50/50 mix with the water. Don't go adding 100% coolant and topping off with water. Buy 50/50 or mix your own, you then have the correct mix to put back in.
The service manual says to just drain out what you can get out and refill with new 50/50 mix. GM feels the remaining Dexcool will still be good for another 5 years. I think this is the best thing to do.
Trying to flush with a hose or even distilled water will mean you need to use a different approach to re-adding coolant. If you flush with water, you should look in the manual and see what the total amount of coolant the system will hold. Mine says 12.6 quarts. Assuming you flushed the system with water, you assume whatever remains in the system after the water flush is 100% water. So, to get the 50/50 mix, pour in 6.3 quarts of 100% coolant and top off with water. No matter how much water you start out with, this brings you back to a 50/50 mix.
That's exactly what the dealership did with my car just drained out coolant and replaced back with same. (I provided them with Amsoil coolant instead). So it's actually easier as you don't have to flush it because you can't so it easier just to do it yourself this way as I was told.Now on my other car I was able to do a complete flush but the water I used is very hard water (tap water) so that's why I think my new 3 row radiator in my other car ended up with scale inside or whatever that stuff is that grows inside. I did use distilled water in the original mix but it was the hard water that was used to flush system that probably caused this problem.
