Climate Control Knobs Too Sensitive
Old Apr 18, 2011 | 10:50 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Default Climate Control ***** Too Sensitive
We had a 2006 3LT with the dual zone climate control, and the detents on the temperature ***** were too "soft"- when trying to change the temp by 1 degree, I would usually end up changing it by 3 or 4 degrees. I worked around that problem by resting my arm and using two fingers, on opposite sides of the ****.
The 2006 was replaced by a 2009, and the ***** are even easier to move too much. Yeah, I can get by with my "two fingers" method, but it's a PITA and takes my eyes off the road for a moment.
Is there an easy way to make the detents more positive, so it takes more effort to turn the ****? The volume control for the radio works well for me, so I know that it can be done.
My dealership is very helpful, and would probably replace the climate head unit if I complain, but the new head would probably be about like the current one.
Any suggestions?
Old Apr 19, 2011 | 05:35 AM
calemasters's Avatar
calemasters
I agree with you, but I think we have to live with it. If the dealer replaced the AC control, it would be debited back as NTF.
Old Apr 19, 2011 | 02:01 PM
Chevy Cust Svc's Avatar
Chevy Cust Svc
I can put in a suggestion if you would like to GM. Just let me know and PM me your info and we can throw a GM Suggestion in for you on this note.
Brent
GM Customer Service
Gearhead Jim
St. Jude Donor '13
I'm wondering if we can remove the **** and put something on that shaft that increases the friction, like a small O-ring. That wouldn't make the detents any better, but might still help the situation.
Old Apr 19, 2011 | 02:14 PM
Gearhead Jim
St. Jude Donor '13
Brent
GM Customer Service
PM sent, thanks!
Old Apr 19, 2011 | 02:18 PM
cclive's Avatar
cclive
If you could actually take the switch apart, the detent spring could be tightened...probably alot of work for a small thing...
Old Apr 19, 2011 | 05:29 PM
cylon's Avatar
cylon
You guys are looking for an "about" or "smidge" button.
"Are you cold honey? I will turn it up a smidge"
it is located next to the EASY button
To Climate Control Knobs Too Sensitive
