Torque lug Nuts
Old Apr 19, 2011 | 11:18 PM
Stinger's Avatar
Stinger
Default Torque lug Nuts
Quick question is it still 125 ft.,lbs. torque on the C-6 lug nuts?
Can't find specs in owners manual. Thanks.
Old Apr 19, 2011 | 11:19 PM
StKnoWhere's Avatar
StKnoWhere
I believe it is 100 ft lbs
Old Apr 19, 2011 | 11:21 PM
MADinAK's Avatar
MADinAK
St. Jude Donor '06-'07-'08-'09-'10,'14
Old Apr 19, 2011 | 11:32 PM
Stinger's Avatar
Stinger
Old Apr 19, 2011 | 11:36 PM
Torchsport's Avatar
Torchsport
St. Jude Donor '15 thru '26
This should be a great reminder for us all to torque those nuts. Especially after a few hundred miles on new cars. Those aluminum wheels like to shake the jug nuts loose!
Old Apr 19, 2011 | 11:38 PM
SimpleC6's Avatar
SimpleC6
100 ft./lbs. on all C6 Vettes.
Old Apr 20, 2011 | 07:00 AM
GOLD72's Avatar
GOLD72
As well as C5 vettes. The correct term is "ft-lbs". It's force times distance.
Old Apr 20, 2011 | 07:14 AM
wera32's Avatar
wera32
Actually it's not. Not sure how to abbreviate it but it's lbs/ft. As in pounds feet. Force times distance is correct.
Old Apr 20, 2011 | 07:39 AM
gilhuly's Avatar
gilhuly
Those aluminum wheels like to shake the jug nuts loose![/QUOTE]
Old Apr 20, 2011 | 07:43 AM
mac823's Avatar
mac823
For 99% of lugnuts I know they say tighten to 98lbs/ft. Haven't read up on what it is for corvettes....but back with Ford I knew they said 100, but what was the most widely recommended was 98. Had an issue with a lug seizing on my BRAND new True Forged wheels when I torques them to 100 (believe it or not).
Old Apr 20, 2011 | 07:46 AM
GOLD72's Avatar
GOLD72
You are wrong!!! Lbs/ft is force value divided by a distance value or force per unit of distance. The correct term of expression for torque can be either lbs-ft or ft-lbs. Torque is a force applied over a unit of distance which is force multiplied by the distance (lever arm). Go look at your owner's manual for torque values and I promise you it will not be expressed as lbs/ft or lbs/in.
http://en.wikipedia.org/wiki/Torque
Look in the Section for Units and discussion about British Units which is also US Customary Units.
Here is an excerpt from the 2008 Corvette Owners Manual Page 5-104 that I cut & paste from a pdf file:
Engine Data
Engine Horsepower Torque Displacement Compression Ratio
6.2L V8 430 @ 5900 rpm 424 lb ft @ 4600 rpm 6.2L 10.69:1
6.2L V8 with option NPP 436 @ 5900 rpm 428 lb ft @ 4600 rpm 6.2L 10.69:1
7.0L V8 505 @ 6300 rpm 470 lb ft @ 4800 rpm 7.0L 11.0:1
Old Apr 20, 2011 | 09:12 AM
JRHAWK9's Avatar
JRHAWK9
Engine Data
you are applying a certain amount of force THROUGH a distance.
Old Apr 20, 2011 | 09:25 AM
FortMorganAl's Avatar
FortMorganAl
From: Currently somewhere in IL,IN,KY,TN,MO,AR,MS,AL, or FL
WOW!!! Where do you get a torque wrench that is accurate to 2% and how much would it cost?
Old Apr 20, 2011 | 10:07 AM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
LB ft is what I call it. 100 of them will secure the wheel.
Old Apr 20, 2011 | 10:09 AM
JSB LS3's Avatar
JSB LS3
I'm a tad OCD so I always tighten to 75, then 100....don't ask me why.
Old Apr 20, 2011 | 10:48 AM
Wayne O's Avatar
Wayne O
CF Senior Member
It depends on what kind of vehicle you drive. Lighter vehicles with smaller wheels/tires/studs or heavier trucks with larger wheels/tires/studs are different. I could be in trouble if I torqued the lug nuts on my 3/4 ton, 4WD Suburban to 100. If memory serves correct I torque the lug nuts on my Suburban to 140 lb-ft. Here's a chart showing general recommended torque values:
7/16" dia. 50 to 60 lb-ft
12mm dia. 70 to 80 lb-ft
1/2" dia. 80 to 90 lb-ft
5/8" dia. 110 to 125 lb-ft
FWIW I would not go with what's "widely recommended." I would always defer to what the manufacturer specifically recommends.
Old Apr 20, 2011 | 11:26 AM
orca1946's Avatar
orca1946
Funny how for 40 years I put nuts on by feel & now we need to be within 2% of some number!!!!!!!!
To Torque lug Nuts
Old Apr 20, 2011 | 11:42 AM
weathermaker's Avatar
weathermaker
Me too, and the wheels haven't fallen off yet!
eboggs_jkvl
Moderator emeritus
Uhhuh, and you didn't need a laptop to tune your car either!
Elmer
Old Apr 20, 2011 | 12:22 PM
cclive's Avatar
cclive
Just do what Jeremy does on Top Gear....he would say that "the Corvette has 424 torques"
