Vibrating Mirror Fixed(!)
Old Apr 22, 2011 | 01:20 AM
sublime1996525's Avatar
sublime1996525
Default Vibrating Mirror Fixed(!)
Like many I've read posts complaining about the vibrating rear view mirror. Well I received some better pins from a forum member and put them in.
This is awesome, I can now drive down the road and see behind me. There isn't a bunch of objects shaking all over. I can move the mirror without it feeling like it's going to break off.
Here is a pic of how bent the pins were. I was surprised by this
Old Apr 22, 2011 | 01:22 AM
fastskyline's Avatar
fastskyline
so where do i get some new pins like you did??
Old Apr 22, 2011 | 02:11 AM
Torchsport's Avatar
Torchsport
St. Jude Donor '15 thru '26
I would like to know as well...
Old Apr 22, 2011 | 07:33 AM
spinalator's Avatar
spinalator
Me too...
Old Apr 22, 2011 | 09:06 AM
pcguy2u's Avatar
pcguy2u
Old Apr 22, 2011 | 09:19 AM
Boomer111's Avatar
Boomer111
Humm, mine is rock solid. Actually kinda of tough to adjust...this looks like one less thing I have to worry about worrying about.
Old Apr 22, 2011 | 09:51 AM
CSixDude's Avatar
CSixDude
Where are these pins located on the mirror?
Old Apr 22, 2011 | 10:21 AM
smurfkiller's Avatar
smurfkiller
i used tig welding filler rod to make new pins for mine. i bent mine removing mirror for tint. i also put a little dab of silicone rtv in there to ensure it wouldnt rattle.
Old Apr 22, 2011 | 10:48 AM
Jimmy Mac!'s Avatar
Jimmy Mac!
I took my 2010 Coupe back to the dealer. Fixed.
Old Apr 22, 2011 | 10:50 AM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Me too! Where do you get the pins and how do you R/R the mirror to fix the issue?
Elmer
Old Apr 22, 2011 | 10:17 PM
sublime1996525
I got the pins from a forum member. I'm not sure where he got them.
To remove the mirror just grab the base and twist counter clockwise (I believe) and it comes right off. Then you have 3 T8 size screws and the pins just come out.
Old Apr 22, 2011 | 10:19 PM
eboggs_jkvl
Moderator emeritus
um... still looking for the source of the pins so I can get some and fix my problem...
Old Apr 23, 2011 | 10:20 AM
pcguy2u's Avatar
pcguy2u
I just straightened mine out on the 05 and if you don't put any torque on the base, it'll be fine for a while - YMMV.
Old May 2, 2011 | 09:22 AM
sublime1996525
I got the pins from a forum member Greg (bassspring). Shoot him a PM.
Old May 2, 2011 | 06:04 PM
chevyc6z51's Avatar
chevyc6z51
was this making rattling sounds before you did this?
Old May 5, 2011 | 02:19 PM
sublime1996525
No it didn't rattle. Just shook like crazy.
Old May 5, 2011 | 03:15 PM
eboggs_jkvl
Moderator emeritus
I took the mirror off. Straightened the pins and reassembled. We'll see if the blurry cars in the mirror settle down.
Elmer
To Vibrating Mirror Fixed(!)
Old May 17, 2011 | 02:07 PM
eboggs_jkvl
Moderator emeritus
Straightening the old pins doesn't do squat.
Old May 23, 2011 | 01:26 PM
eboggs_jkvl
Moderator emeritus
Well, Craig (bassspring) mailed me some stainless steel springs mirror rods. I just installed them and the "play" is gone in the mirror. I can tell immediately that the vibration is dampened.
Thanks a ton Craig! These springs are the shiznitz!
Elmer
Old May 23, 2011 | 02:59 PM
spinalator's Avatar
spinalator
I just sent him a PM. He should sell these...
