Ground Clearance?
Old Apr 27, 2011 | 08:26 AM
69L79's Avatar
69L79
From: Hamilton Square NJ, Ocean City N. J. Key Biscayne Fla.
Default Ground Clearance?
What is the "official" ground clearance on a stock Vette. I need, at least, four inches for the Auto Train to Florida. Thanks.
Old Apr 27, 2011 | 10:03 AM
JoesC5's Avatar
JoesC5
I believe it is listed at 4.7".
Old Apr 27, 2011 | 10:20 AM
Wayne O's Avatar
Wayne O
CF Senior Member
I'd check to see if other C6 Corvettes are using the auto train without issue. The listed ground clearance number may not be the only consideration. Good luck!
Old Apr 27, 2011 | 10:37 AM
Who Needs Turbo's Avatar
Who Needs Turbo
I believe the front air dam is 3.75", but the important bits are at least an inch higher.
Old Apr 27, 2011 | 11:44 AM
cclive's Avatar
cclive
My front air dam is 2.5" when the car is in the garage...stock. The static ground clearance is probably not the most important measurement for the auto train...breakover height etc might be more important. For me, it was the important one when getting the car onto an alignment rack.
Old Apr 27, 2011 | 11:59 AM
arcticZ51's Avatar
arcticZ51
Speaking of which where in world do you go for an alignment after you lower your car? I know they recommend it after lowering it but, then won't it be too low for most shops to do it?
Old Apr 27, 2011 | 12:05 PM
RicK T's Avatar
RicK T
Here are a couple old Auto Train threads just for info:
http://forums.corvetteforum.com/c6-c...uto-train.html
Old Apr 27, 2011 | 12:13 PM
KenHorse's Avatar
KenHorse
From: I live my life by 2 rules. 1) Never share everything you know. 2)
St. Jude Donor '11-'12-'13, '16-'17-'18
Any reputable shop that can do 4 wheel alignments should be fine.
Old Apr 27, 2011 | 01:20 PM
CH-Z51's Avatar
CH-Z51
From: The Great Pacific Northwest...........I carry a gun cause a cops too heavy.
Been lowered for 3 years and have yearly alinements without any troubles.
Old Apr 28, 2011 | 04:36 PM
AlfredMay's Avatar
AlfredMay
My 2010 Vert has a front air dam that has a fraction over 3.5 inches of clearance in the center.
Old Apr 28, 2011 | 04:54 PM
69L79's Avatar
69L79
Thanks for the responses. I will be taking the Auto Train to Florida. I called Lorton, Va. And, they have been routinely transporting stock clearance Vettes with no problems. "Lowered" Vettes could be a problem.
Old Apr 28, 2011 | 05:38 PM
KenHorse's Avatar
KenHorse
By the way, the only time ground clearance has been an issue for me is behind a yolk or a cyclic, not a steering wheel
To Ground Clearance?
