Homelink
Old Apr 30, 2011 | 03:06 PM
wirebender's Avatar
wirebender
Default Homelink
Just got new gs. Have overhead door opener. No smart button. Have tried what the manual says, no luck as of yet. Help appreciated
Old Apr 30, 2011 | 03:43 PM
RicK T's Avatar
RicK T
First, you don't have Homelink, the system in these cars since late '07 is the Lear Car-2-U. And yes, they can be difficult. Not knowing what you have, I'll just refer you to these threads that may help. The tech support number for Lear is included if you need to call. Good luck.
http://forums.corvetteforum.com/c6-c...home-link.html
http://forums.corvetteforum.com/c6-c...now-works.html
Old Apr 30, 2011 | 03:44 PM
Stan0324's Avatar
Stan0324
I own a 11 GS. I have the sears brand grarage door opener. I just hit the button on the back of the opener and followed the instructions in the manual and everything worked. Forgot exactly what it said, but basically you hit all 3 buttons, once they blink, you hit the one you want to use to open your garage. Its something like that.
Old Apr 30, 2011 | 04:18 PM
Torchsport's Avatar
Torchsport
St. Jude Donor '15 thru '26
OP stated he didnt have the Smart button, or as labeled on some openers, Learn button. Probably has an old opener.
I have mistakenly called the 3 button controller Homelink as well.
Old Apr 30, 2011 | 05:07 PM
Cybernetic Medic's Avatar
Cybernetic Medic
My garage door opener is a 30yr old Gene screw drive. It still works like a champ but there was no way it would be compatible with the opener in the vette. I got an adapter on line that is basically a new compatible receiver that connects parallel to the manual door opener button. It was about 25 bux and works great.
http://learcar2u.com/conversionmodule/
Old Apr 30, 2011 | 06:24 PM
FNwoz's Avatar
FNwoz
Do you know if there is anyway to program two doors with one module? I have a two car garage with two separate doors and openers. Seems like I would need two in this case. Thanks for the incite on this as I have been looking for something like this.
Old Apr 30, 2011 | 06:29 PM
SolidlyStated's Avatar
SolidlyStated
C7 of Year Finalist (stock) 2019
I would think that with 3 buttons, you could do 3 doors if you wanted.
I had trouble with mine until I realized there were multiple setups in the manual and I was doing the wrong one. I initially tried hitting visor buttons with the button on back of the door fixture, but actually needed to be holding the remote button and visor buttons
Old Apr 30, 2011 | 06:36 PM
Cybernetic Medic
You're very welcome.
No, you would need two modules unless you wanted both doors to open and close together. With separate modules you could, of course, program each for a different button on the sun visor.
Old Apr 30, 2011 | 08:01 PM
Bonefishmak's Avatar
Bonefishmak
Hmmmm Id like to do this but if I have to get to the garage door opener I'll need to buy a ladder. I'm in an apartment and rent a garage....so, not sure what I have.
Old Apr 30, 2011 | 08:09 PM
Torchsport's Avatar
Torchsport
Top off, shoes off, stand on the seat.
Problem solved!
Old Apr 30, 2011 | 08:24 PM
Bonefishmak
Problem solved!
I like it! Thinking OUTSIDE the box!
Old Apr 30, 2011 | 08:46 PM
phileaglesfan's Avatar
phileaglesfan
Homelink worked great with my garage door opener (newer Martin), Lear2u does not work at all. Someday I'll buy their stupid "adapter" for each garage door. Meanwhile I have the garage door opener clipped to the visor in each of my cars.
Old Apr 30, 2011 | 09:14 PM
DebRedZR1's Avatar
DebRedZR1
Moderator
CF Banner Relay Captain
West MI & JAX/NE Florida
Events Coordinator
St. Jude Donor '11-'17, '21
I had problems getting my GS programmed too. My GMC Acadia was EZ. Nephew had to do the GS. Good idea on the standing on seat I still have to have the ZR1 done
To Homelink
