flaking trim tips?
May 21, 2011 | 02:28 PM
C7 of Year Finalist (stock) 2019
flaking trim tips?
All the window trim is like this.
Any suggestions?
Also is there a way to take care of the rubber trim so it stays "healthy?"
May 21, 2011 | 05:34 PM
I have the same issue. Great GM quality control.
I'm not aware of a 'fix'.
Anyone?
Quote:
Originally Posted by
SolidlyStated
Any suggestions?
May 21, 2011 | 06:48 PM
From: I live my life by 2 rules. 1) Never share everything you know. 2)
St. Jude Donor '11-'12-'13, '16-'17-'18
Best thing for rubber trim is silicone lubricant. NEVER use anything containing petroleum products...
May 21, 2011 | 06:49 PM
American quality. Same here. Let it all flake off
May 21, 2011 | 06:55 PM
It only happens on those vehicles that have the lavender trim option.
May 21, 2011 | 07:08 PM
AirBusPilot
Damn! Okay I traded in my lavender, but now my black trim has the same problem!
May 21, 2011 | 07:18 PM
AirBusPilot
May 21, 2011 | 10:02 PM
KenHorse
Will any ole' silicone lubricant do or is there a specific brand recommendation?
There's a dirty joke to be made here, but I will refrain
May 21, 2011 | 10:06 PM
SolidlyStated
Any silicone spray lubricant works fine - I spray a rag with it and then wipedown whatever I'm wanting to clean and lube.
May 21, 2011 | 10:11 PM
Try using Aerospace 303...great stuff for that.
May 22, 2011 | 03:44 AM
St. Jude Donor '11-'12-'13-'14-'15
Aerospace 303 provides excellent protection against UV light.
I'm no expert on the subject but the pic looks like the kind of damage seen on other cars that are parked outside all the time.
May 22, 2011 | 07:40 AM
My car is NOT parked outside very often...I'll stick with the quality comment.
**** Jockey
May 22, 2011 | 10:04 AM
None of the A-pillar on my '06 Coupe has any paint on it. Never has. Why does yours?
May 22, 2011 | 02:47 PM
St. Jude Donor '13
Our 2006 didn't experience this, neither has our current 2009; so I can't directly help.
However, someone previously posted that the flaking stuff is not supposed to be there at all, the solution is to remove it completely and leave the underlying material exposed like it should be.
Does that look practical, or was the previous poster misjudging the situation?
May 22, 2011 | 06:37 PM
rc135_tx
These trim pieces on my '08 are black, unpainted, with no peeling issues whatsoever. Did these pieces get painted on earlier models?
May 23, 2011 | 10:50 AM
My 08, pass side is doing the same thing, I will order the Aerospace 303 and give it a try.
May 23, 2011 | 11:37 AM
SolidlyStated
So it's showing lavender now, huh.
May 23, 2011 | 11:58 AM
My brand new Coupe had that. Warrenty replaced all my rubber on the outside recently.
May 23, 2011 | 12:06 PM
Jimmy Mac!
Great, our 09 is doing that and I will need to take it in before the 3 years are up and get it all replaced and then lube it or 303 that I use on the interior
May 23, 2011 | 01:33 PM
Chevy replaced driver side under warranty on my 08 vert. There are several part #s for this because I had to go back to the dealer twice until they got them all ordered. The passenger side is OK.
