New WindRestrictor install
Old May 27, 2011 | 10:09 PM
banjo04072's Avatar
banjo04072
Originally Posted by AORoads
seems like the bare bones price is 399. at that price, imo it better work at least to the tune of the 40%-50% you say w. windows down. otherwise, again imo, it'd be a waste of money other than the good looks of having something scrawled on it, or some lights-fantastic display.
Got a real good price and free shipping. Lower then what you quoted. But, I've seen alot more expensive "mods" on the forum, I guess each to his own.
I wanted something for the highway speeds, didn't want to have to remove and store, like the OEM look and am happy with the purchase. Agree about anything connected to the name "Corvette" being expensive, but what one would consider a waste of money another thinks that's where they want their money on a "mod".
Old May 28, 2011 | 02:00 AM
iflex2fitness's Avatar
iflex2fitness
[/center][/QUOTE]
Can you post a couple pictures of the top view looking down and a picture that shows where and how it is installed? Thanks.
Old May 28, 2011 | 08:57 AM
jcdreamer's Avatar
jcdreamer
It looks really nice. I would love to see a side view picture please.
Old May 28, 2011 | 09:52 AM
banjo04072's Avatar
banjo04072
Old May 28, 2011 | 11:13 AM
AeroJim's Avatar
AeroJim
St. Jude Donor '08-'09
For $399 , i'll take the wind in my hair, thats why I bought a convertible in the first place
Old May 28, 2011 | 01:29 PM
Tin Star's Avatar
Tin Star
From: Amelia Island,FL ______ or DFW _________ Sold my 05 MS Coupe ____ bought 08 Vert Blk/JSB, 3LT, F55
Sometimes (strike that)
ALWAYS
pays to keep the wife happy
Old May 28, 2011 | 01:35 PM
Tom_Slick's Avatar
Tom_Slick
ALWAYS
Yes, the wife would possible prefer it to her hair blowing in the wind... I like to wear a baseball cap when I drive on cool nights/ hot days... Not having to put up the top/ holding onto my cap by the bib to keep it from being blown off when I drive on the highway is another good reason for buying it.
Old May 28, 2011 | 01:44 PM
jpuli28's Avatar
jpuli28
Would this work in the coupe when the roof is off?
Old May 28, 2011 | 02:19 PM
Tom_Slick's Avatar
Tom_Slick
Originally Posted by iflex2_fitness
[/center]
Can you post a couple pictures of the top view looking down and a picture that shows where and how it is installed? Thanks.[/QUOTE]
Maybe this will help... You'll need to pull back the carpet/ trunk partition, and with the supplied brackets, use existing holes to attach the brackets to the seat belt supports... They suggest removing the speaker connection, I didn't. Once the brackets are in, replace the carpet pieces, put in the Wind Restrictor(4 bolts/ 4 nuts) and you're done. 30-45 min install...
ttp://www.youtube.com/watch?v=RAkjX957gXg Pic from inside a car with the top up...
More pics...
The brackets are similar to these...
Old May 28, 2011 | 02:35 PM
RAT's Avatar
RAT
I like it!
Old May 28, 2011 | 08:54 PM
akriggm's Avatar
akriggm
To those that have this new WindRestrictor - what is the view like in the rearview mirror with the top up and down?
Enjoy,
akriggm
Old May 28, 2011 | 09:30 PM
banjo04072's Avatar
banjo04072
Enjoy,
akriggm
That was one of my concern's before installing it. Turns out I didn't find it to be a problem at all. Even with the etching on it.
Old May 30, 2011 | 08:19 AM
  #33
ontcanuck's Avatar
ontcanuck
Although I love this setup I fell the ideal unit should still be able to be removed easily. I would not like to have this unit mounted all the time so it should be easily removable any time you want to.
Old May 30, 2011 | 09:38 AM
  #34
TOBASCO's Avatar
TOBASCO
CI 2-4-5-6-7-8-10-11-12 Vet
NCM Ambassador
St. Jude Donor '08-'11-'13-'14-'15
I like having the windows down while topless driving. The car just doesn't look right with the windows up IMHO. So my question is is there any buffeting or increased noise from the unit when the top is down and the windows are also down at highway speeds? I would get this primarily for my wife who doesn't like her hair blown around and she makes me put the windows up
Thoughts?
Old May 31, 2011 | 08:31 AM
  #35
jcdreamer's Avatar
jcdreamer
Old May 31, 2011 | 09:46 AM
  #36
banjo04072's Avatar
banjo04072
Thoughts?
That is a hard question to answer. It definitely is not like you have the top up with the windows closed!
What this does is reduce the buffering effect in the seating area significantly. It makes it quietier for sure. We can talk at highway speeds whereas we couldn't before. Things aren't blowing all over the place. You don't get the chill as much when it's cold.
I don't think it's meant to remove those effect's, but to reduce them. IMO, there is nothing that is going to take away from your hair being blown around or remove the buffering completely.
Lastly, everyone is different. What might work for me wouldn"t for you.
Old May 31, 2011 | 10:07 AM
  #37
Tom_Slick's Avatar
Tom_Slick
There are 4 screws/ 4 bolts to hold it in place... Without removing the brackets you could use the bolts and wing nuts if you'd like to quickly install/ remove it. The only thing I'd worry about would be because its hard plastic vs glass is getting scratches while handling/ storing it.
To New WindRestrictor install
Old May 31, 2011 | 11:01 AM
  #38
Tom_Slick's Avatar
Tom_Slick
Originally Posted by speedlink
My question is, does it work? And if so, what is the difference (other than you can keep it installed all the time) between this and a Vette screen. The Vette screen seems higher , even behind the seats. So, I would think it would block the air more effectively.
Having owned both I think the difference is the permanent install/ not having to install/ remove it to raise/ lower the roof. It also doesn't have the thick frame around it which for me created sort of a blind spot when looking thru the rear view mirror. As far as blocking the air the WindRestrictor works as well or better because its made to fit lower between the seats and match the contour of the Waterfall, thus blocking more air. Like I said in an earlier post I like the Vette Net but this works better.
You can see in the above photo the the original Vette Net could block your view thru the rear view mirror.
Old May 31, 2011 | 11:39 AM
  #39
Redshift's Avatar
Redshift
Platinum Supporting Vendor
Looks like most questions have been answered already, but if anyone has questions on this item, please don't hesitate to ask us. We have fast response times and a low price guarantee and have been a long term headlining sponsor of CF for many, many years.
__________________
Brian - ** I am no longer associated with PFYC.com **
Old Jun 6, 2011 | 11:12 PM
  #40
Flametop's Avatar
Flametop
Navigator
Default windrestrictor
Did you install it yourself? Was it difficult?
