Tips for pulling battery out of 06 Coupe
Old 05-30-2011, 10:10 AM
tdb
tdb's Avatar
Default Tips for pulling battery out of 06 Coupe
I have checked out all of the threads in a search but still can't determine the best way to grip and tilt the battery (to avoid any spillage through the vents as I move it) when pulling it out.
I know it is a silly question but any help in getting it out without erroring on the side of dropping it would really be appreciated
Old 05-30-2011, 10:18 AM
RicK T
RicK T's Avatar
I haven't done it yet but I don't recall anyone ever posting having any problems with spillage. I don't think it's any big deal.
For encouragement you can check this site. Click on "Battery-Optima" in the yellow pane on the left. About half way down he has an "Installation" heading with pics.
http://www.bugmanweb.com/c6/c6index.html
Old 05-30-2011, 10:19 AM
vette6500
vette6500's Avatar
just gotta muscle it out. tip it forward a bit for clearance and reach in to grab as much as you can and pull it out. put on some gloves for extra grip and keeping hands somewhat clean. but then i am just a medium and can eventually get one of my hand/arm down to grab the bottom of the battery. if your arms are too big, you are stronger, so get latex gloves on and grip/squeeze 2 sides/corners of battery and extract it with your muscles!
Old 05-30-2011, 10:20 AM
R&L's C6
Support Corvetteforum!
R&L's C6's Avatar
Received 1,255 Likes on 709 Posts
When I took mine out of my 05 I put a foam fender cover over the fender and some bath towels around the engine area. Then I lifted and held on with grip like a gorilla.
Old 05-30-2011, 10:25 AM
Cybernetic Medic
Cybernetic Medic's Avatar
+1 and don't forget to cover the fuse box. It's a natural place to rest the battery when you're taking it in or out. It seems like half the fuse box covers I see at cruise-ins and car shows are scratched up.
Old 05-30-2011, 10:26 AM
smurfkiller
smurfkiller's Avatar
it shouldnt have any vents to spill out of. if your that worried replace it with a optima. they can be mounted upsidedown.
Old 05-30-2011, 12:53 PM
VET4LES
VET4LES's Avatar
I just grabbed mine and lifted it out. Just like I've been doing for many years. Just do it.
Old 05-30-2011, 01:16 PM
speedlink
speedlink's Avatar
Can't you use a battery strap? They are available at most automotive stores for a couple of bucks. They have hooks that just go in a slot on the battery and you lift it out.
Old 05-30-2011, 01:21 PM
j_digi454
j_digi454's Avatar
Old 05-30-2011, 03:26 PM
MARSC6
MARSC6's Avatar
Don't worry about spilling. Just grab it and tilt whichever way you have to. I've done it several times without any trouble.
Old 05-30-2011, 07:36 PM
talionstallion21
talionstallion21's Avatar
You just have to reach in there and pull it up and out. Don't forget there's a battery hold down bracket that you have to loosen first, at least in mine there was. You'll need a socket extension to get at it.
Old 05-30-2011, 07:45 PM
Gman in NC
Gman in NC's Avatar
Good info from everyone here. I changed mine in January and it was very easy. I did use a pair of gloves with the little rubber dots all over them. Make's it easy for sure. I also put my new battery on a 1 amp charger for 24 hours before I put it back into the car. They can sit on the shelf for quite some time.
Old 05-30-2011, 08:12 PM
Chalie M
Chalie M's Avatar
lock a vise grip on one of lead post, tilt and lift out.
Old 05-30-2011, 09:40 PM
beaversstonehaven
beaversstonehaven's Avatar
My little trickle charger to almost exactly 24 hrs. to turn green. I'm glad I did it.
Old 05-30-2011, 10:21 PM
florida john
florida john's Avatar
Sorry to go off topic, beaverstonehaven, but isn't that a Triumph in your photo? Is it one of the new ones?
Old 05-31-2011, 04:50 AM
bolivar
bolivar's Avatar
Use an old belt, or something like that. Tilt one end up a little, slide the belt under the battery to the middle, grab both ends and lift it up.
Old 05-31-2011, 06:04 AM
SteveL4446
SteveL4446's Avatar
Agree. Get a battery strap. It will make your life easy!
To Tips for pulling battery out of 06 Coupe
Old 05-31-2011, 06:27 AM
Mischief
Mischief's Avatar
Did this last night and there really isn't any special technique to it. Just grab the battery in a couple of spots, angle it accordingly, carefully lift and out it goes. To be on the safe side use a fender cover and towels around the surrounding area in the engine bay to avoid possible scratches.
Old 05-31-2011, 08:21 AM
FloydSummerOf68
FloydSummerOf68's Avatar
Are these really problems that people have?
Just pull it out.
A battery strap?!?! It's unfortunate that something like that even needs to exist
Old 06-13-2011, 03:18 PM
SteveL4446
SteveL4446's Avatar
That's the best way. The strap costs about 4 bucks, and helps you pull the dang thing right out. 30 second job start to finish.
Quick Reply: Tips for pulling battery out of 06 Coupe
