Something burning or normal?
Old Jun 2, 2011 | 01:58 PM
DigitalWidgets's Avatar
DigitalWidgets
Default Something burning or normal?
Newer Vette owner here (2011 GS, 9 months, 10K miles). I've noticed something since the car was new that I thought I'd run by the collective for advise:
Whenever I make excursions in to the "above 3500 RPM" range (spirited acceleration perhaps, but not WOT by any means) I've noticed a distinct burning smell. Not a burning like something is on fire (i.e. not smoky, or exhaust like), and not like something is being damaged (i.e. not like electrical circuit blowing or burning rubber or plastic). My initial impression was that perhaps the exhaust pipes were getting very hot and what I was smelling was something like detailing spray over spray on them or something (which I can't imagine how that would get there, but that was an initial impression). It's not even that unpleasant, but it becomes apparent anytime I push the car a bit (I typically drive with the windows up and AC on).
Anyway, I thought it was a new car thing that would fade over time, but here 10K miles later, it's pretty much the same. Since I'm taking it in for an oil change next week, I'd thought I'd ask the Forum if there's anything to have checked when it's in the shop.
Normal?
Old Jun 2, 2011 | 02:15 PM
brooklync5's Avatar
brooklync5
Could be you ran over a plastic bag but that would have faded by now. If your car had 500 miles on it the smell would be normal if you pushed it a bit but at 10k those break in smells should be gone. I'm stumped! Sorry.
Old Jun 2, 2011 | 03:54 PM
DigitalWidgets
Yeah, a "break in smell" would be an accurate description. Not like something is on fire, just like something is getting real hot for the first time. I did check for bags, etc. but have found nothing yet.
Old Jun 2, 2011 | 04:28 PM
B y r o n's Avatar
B y r o n
Does your car have the dual mode exhaust?
If it does maybe it just hasn't cooked off all the newness of the center two tips.
I had someone ask why by center two tips were brown when the outside were still polished. I explained that I had the dual mode turned off so everything exits the center two, bypassing the outside two.
Just making a guess.
Could it be a little anti-freeze overflow?
Old Jun 2, 2011 | 04:56 PM
06 C6 vert's Avatar
06 C6 vert
No worries, mine still has a nice toast smell when I do WOT.
When it was new , much more pronounced .
Old Jun 2, 2011 | 05:00 PM
sprtplt's Avatar
sprtplt
Normal when new, sure. But 10k miles later? I have never experienced anything like that.
Old Jun 2, 2011 | 06:39 PM
DigitalWidgets
Originally Posted by B y r o n
Does your car have the dual mode exhaust? If it does maybe it just hasn't cooked off all the newness of the center two tips.
Hmmm....I do have NPP and a home made exhaust controller switch. I do tend to leave the ports open 95% of the time. And that RPM that triggers the NPP system (3500) is kinda/sorta related to when I notice the smell cropping up.....but as I understand it, leaving the ports open all the time isn't supposed to create any issue (somebody jump in and correct me if I'm wrong in that assumption). Maybe it's the inverse...a little extra pressure is blowing some of the hot exhaust into the relatively unused muffler'd exhaust path.
Old Jun 2, 2011 | 06:50 PM
door2416's Avatar
door2416
I have a 2010 GS and when I push it I do get a smell that I would say smells more like burning oil. (very slight) It happens around the same rpms that you are stating. 3500 to 4500.
Old Jun 2, 2011 | 06:52 PM
mneblett's Avatar
mneblett
Cruise-In VIII Veteran
When my '08 was relatively new, I had a burning oil smell that drove me nutz for a couple weeks. I finally found where a drop or two of oil had fallen on the front right cylinder exhaust manifold that I didn't see the first couple times I checked -- that tiny amount took forever to burn off. I assumed that I put the drops there checking oil level or opening the fill cap - dunno. A couple hits on the residue with carb cleaner and the burning oil smell was gone.
Old Jun 2, 2011 | 06:56 PM
hondaamer's Avatar
hondaamer
Normal?
I had an '06 coupe that had that exact smell whenever I opened it up a little. No one could find what it was. I now have an '010 coupe with the NPP and the same exact problem. I feel your pain brother, I would love to know what it is, because I would love to do without it.
Old Jun 2, 2011 | 07:08 PM
DigitalWidgets
Yeah, I guess I don't mind it....I just want to know what it is.
It would be nice to explain to passengers something like "yeah, the exhaust pipes get red hot!" or something that sounds like a performance car type of thing. Instead, right now I get to hear my 8 year old daughter say "EEWWE, smells like Betty just farted!"
Old Jun 2, 2011 | 07:17 PM
door2416's Avatar
door2416
Mine only smells when i get on it a little. If I drive relative lower rpms there is no smell. It seems like if there were oil on the engine it would smell all the time.
Old Jun 2, 2011 | 07:31 PM
glenB's Avatar
glenB
St. Jude Donor '08-'09 & '12, '14
That's cuz you're running the 'stink' out of it.
Mine used to do that until I took the cats off, their furr would melt
But really, mine smelled like clutch material after a run yet I have no problems with the clutch and the smell has been gone for awhile now.
Old Jun 2, 2011 | 07:32 PM
EVRose's Avatar
EVRose
My '05 does the exact same thing with 42K miles. It's not really a bad "somethings wrong" smell but almost like what you'd expect when a huge burst of power gets released and this is the aftershock smell lingering. I punched it HARD one time with my wife in the car and she commented on it saying you can smell the power.
Old Jun 2, 2011 | 09:30 PM
indyjack18's Avatar
indyjack18
Mine has 2k miles and smells to high heaven......like burnt clutch Can't wait till it goes away.
Old Jun 2, 2011 | 09:34 PM
C6~Missle's Avatar
C6~Missle
It's the ECM making the fuel mixture rich going to WOT.
My other 2 cars also do the same.
Old Jun 2, 2011 | 10:41 PM
RonsGS's Avatar
RonsGS
St. Jude Donor '12-'13
I've got 3k on mine and get that "burnt clutch" smell on mine also. It's most noticable when I back into the garage but not all the time.
To Something burning or normal?
Old Jun 2, 2011 | 10:50 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Old Jun 2, 2011 | 11:18 PM
carjo's Avatar
carjo
Its a 2011 - a brand new car. It wouldn't hurt to have your dealer check it out. Maybe its nothing. Maybe not. Have your dealer check it out... you'll rest easier.
Old Jun 2, 2011 | 11:35 PM
DigitalWidgets
Well, I'm slightly relieved that some of the rest of you have a similar situation. I was going to take the car for an oil change next week, but I called the dealer today and he fit me in. I asked the service guy and he said it's probably nothing but he'll have his guy take a look. Nothing noted. He did however note that my rear tires are approaching the wear bars and recommended a replacement.
Hmmm....need new rears after only 10,000 miles....and a burning smell....maybe I need to go a little easier on Betty!
