wheel spacers -- base c6
Old Jun 7, 2011 | 11:26 AM
david2613d's Avatar
david2613d
Default wheel spacers -- base c6
hey guys, i have a 2008 base c6, i wanted to fill out the rear fenders abit by adding wheel spacers to push out the rear tires just a tad bit, has anyone done this before?
Old Jun 7, 2011 | 11:33 AM
FloydSummerOf68's Avatar
FloydSummerOf68
Lots of people have done it on lots of vehicles.
No problem with doing it on the C6. What you're talking about shouldn't even require longer studs or deeper lugnuts.
Old Jun 7, 2011 | 11:40 AM
david2613d's Avatar
david2613d
yeah, i just want to make the rear more flush with the quarter panels.
are there any pictures of this done?
Old Jun 7, 2011 | 11:52 AM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
IMHO, 3mm same studs no issues. 5mm needs longer studs for the lug nuts
I just went through a Wilwood brake replacement and I required spacers for the calipers. I used 3mm on the rear and the oem studs, the fronts needed 5mm and I wasn't happy with the number of turns of the lug nuts. I went to the ARP 100-7708 studs and now I'm comfortable with the front wheel attachment.
Elmer
Old Jun 7, 2011 | 12:00 PM
JRHAWK9's Avatar
JRHAWK9
Get some nice aluminum custom spacers made at Motorsport Tech and then get some extended thread lug nuts and you'll be set.
Old Jun 7, 2011 | 12:16 PM
Wayne O's Avatar
Wayne O
CF Senior Member
Most people use spacers for a functional purpose rather than for appearances. Ultimately, I'd look for different wheels/tires to solve your appearance problem (and for improved functionality) but using spacers should work fine. CCW makes some extremely nice spacers (or 'hub extenders').
Old Jun 7, 2011 | 12:17 PM
JRHAWK9's Avatar
JRHAWK9
I agree, although as long as the spacers are 0.30" or thinner, those ET lugs (which add another 0.30" of thread) will give you as much or more thread engagement than OEM, depending on how thick of a spacer one uses.
To wheel spacers -- base c6
