Installing Fender Stripes
Old Jun 11, 2011 | 09:29 AM
georgehafe's Avatar
georgehafe
NCM Ambassador
Cruise-In 1, 2, 6, 8 Veteran
Default Installing Fender Stripes
Any help and info on this? I don't want to screw it up to bad and I want to do it myself. Thanks in advance
Old Jun 11, 2011 | 11:45 AM
MINI&aVette's Avatar
MINI&aVette
You want to do it the wet method. Do a search on the mix but its dish soap and water in a spray bootle and it's pretty easy. You can move the stripe if your not happy then squeegee and let dry. Don't forget to remove wax before install and let it sit out in the sun.
Old Jun 11, 2011 | 11:47 AM
not08crmanymore's Avatar
not08crmanymore
The easiest,most cost effective way for me was to have the local pro do it!No fuss,no muss and they look great!
Old Jun 11, 2011 | 12:25 PM
Xedes's Avatar
Xedes
I've done it twice myself without any issues. I went to local auto parts and purchased their window tint kit. It comes with the solution you need and a squeegee. Clean the fenders really well. Spray solution on the fender area generously. Peel the decal and spray the decal with the solution also. Place the stripe in the position you want it ( since it's wet you'll be able to move it around with ease). Once you are happy with the position, hold it in place with one hand and start to squeegee the solution out with the other hand. If it happens to move on you, re- wet it and adjust it. Also, start in the middle of the decal and work your way out towards the edges.
When you're all done you can put the car in the sun to dry out or use a blow dryer/ heat gun ( set on low ) and go over the decal with a micro fiber towel. Your done at this point.
Old Jun 11, 2011 | 12:47 PM
georgehafe's Avatar
georgehafe
NCM Ambassador
Thanks guys
Old Jun 11, 2011 | 01:37 PM
mpuzach's Avatar
mpuzach
Do the stripes come with some type of positioning device? I'm assuming that GM specifies an exact location on the fender, no?
Old Jun 11, 2011 | 06:21 PM
Xedes's Avatar
Xedes
The bottom of them are curved to match the fender curvature. It's pretty obvious when you're doing it.
Old Jun 11, 2011 | 07:52 PM
Triple_Black_in_OC's Avatar
Triple_Black_in_OC
Where are you guys finding the stripes for a decent price? I've been looking but they're either priced way to high or terrible reproductions.
Old Jun 11, 2011 | 07:59 PM
Racer's Avatar
Cruise-In III Veteran
St. Jude Donor '11
Yea, I had a Vendor tell me not to buy those ones shown here because he is going to start selling them, guess what, times up, that was like three months ago, I am buying these ones, please PM where you got the C/F ones.
Old Jun 11, 2011 | 08:35 PM
Xedes's Avatar
Xedes
www.vettestripes.com Mike is a great guy to deal with.
Old Jun 11, 2011 | 08:38 PM
Xedes's Avatar
Xedes
1) A soft bristled detail brush will remove that wax build-up around your edges.
2) Are you parked in a handicap spot?
Old Jun 11, 2011 | 11:27 PM
mpuzach's Avatar
mpuzach
How do you determine the "front / back" positioning?
Old Jun 11, 2011 | 11:29 PM
LionGS's Avatar
LionGS
OEM ones have a mark to line up with the headlight if I remember correctly.
Old Jun 11, 2011 | 11:40 PM
not08crmanymore
1)Thanks.
2)
Old Jun 11, 2011 | 11:56 PM
Racer's Avatar
St. Jude Donor '11
1)Thanks.
2)
Where did you get your stripes, they are the ones I want. I don't think those are vettestripes.coms.
Old Jun 12, 2011 | 12:33 AM
TommyV's Avatar
TommyV
St. Jude Donor '06-'07-'08-'09-'10-'11-'12, '16
Old Jun 12, 2011 | 06:55 AM
gsx1300r's Avatar
gsx1300r
Mid America Motorworks has colored one and two sided kits for less than $40 if I recall correctly on the two sided kit. One side is approx $25.
Stand by for a picture perhaps in a month or so? They are drop shipped from their Manf if I remember correctly.
To Installing Fender Stripes
Old Jun 12, 2011 | 07:11 AM
door2416's Avatar
door2416
I just put mine on last week. They were oem. The wet method is the only way to do it. The oem comes with a template. It was very easy. The wet method gives you time to move them around to get them just right. Go on youtube and look under decal install and you will find many videos to help but if you ever built a model plane when you were a kid and put the decals on it's just that easy.
Old Jun 12, 2011 | 07:27 AM
door2416's Avatar
door2416
Use isopropyl alcohol to clean the wax off the area. I went over mine a couple times until the micro fiber rag started to drag (you will feel it). The water solution is 24 ounces of water and 2 drops of uncented dish soap. That is the directions in the oem kit. You will also need some kind of plastic sqeegee.
Old Jun 12, 2011 | 10:47 AM
not08crmanymore
Not them.There was a guy who posted on here last month.I'll look for the link.I love these things!!Best ones I ever got.
