Is the GS mostly cosmetic upgrades or are there drive-line upgrades in the package. I guess what I'm looking for is what you get for the added cost for this option. Thanks
If you compare it to an 09 coupe with z51 option then it is mostly cosmetic difference, wider body and tires plus somewhere around $5,000 more bucks MSRP.
The difference is you using the SEARCH function. I usually wouldn't say that but you've been a member for a long time now. You should know the difference by now. This seems like a bait thread and you appear to be a
From: North/Central NJ - a.k.a. Gotti in the CFNE section
St. Jude Donor '05
How come the automobile mags achieved .2 seconds in both 0-60 and 1/4 mile and a higher MPH with the grand sport vs base c6? Did the dry sump pump make a difference, or wider body/tires/suspension?
COME ON PEOPLE, we all know this has been asked a thousand times before in a thousand different threads and it all ends in fights and locked threads, you are not new members here, smarten up.
How many threads on this have we seen? Go to the Chevy website, compare the specs, then add up the cost of the upgrades, $5,000 over a base Vette is a great deal for what you get, you do the math.
