Universal Antifreeze
call me crazy but even if it was a dollar, I probably wouldn't use it. I've used some "universal" fluids before in cars. sometimes it's ok, and sometimes the results are horrible.
http://www.imcool.com/articles/antif...l2007Part1.php
From the test reports I've read, you actually can mix DexCool with other brands, but it dilutes some of the corrosion inhibitors, so you have to change it sooner. But they claim it doesn't cause sludge if you mix it.
Though I agree with you and I'd rather not see it mixed. I think it would be better to flush it completely if you are going to change it, just to be on the safe side.
There is nothing "magical" about DexCool, and using another type or brand is not going to make your call melt into a blob of goo in your garage. DexCool is really the only brand/type antifreeze that has been associated with problems, and many car manufactures (like Toyota) will actually void your warranty if you put DexCool in them. This is due to the acid technology that DexCool uses not being compatible with some seal types. This is why all other antifreeze companies don't use the 2EH acid in their formulations. So if there really is any one type to be afraid of more than others, it's DexCool. Though the seals in the Corvette are designed to withstand it, but even so, I still don't like the stuff. Notice the warnings in your service manual that tell you not to spill it on the paint or on any of the composite panels of the car. Ask yourself why that warning is in there. Its because the acid makeup of the DexCool additives and how it affect various materials it comes in contact with.
DexCool and other "Extended Life" or "Long Life" (OAT/HOAT) antifreeze formulations were invented to try to lengthen the amount of time between antifreeze changes. They really aren't any better in terms of corrosion control, cooling, or freeze protection, they just use additive packages (organic acid) that are "supposed" to last longer. Furthermore, many of the problems that have occurred with DexCool have been attributed to it being left in the car for so long, and that it got ignored and allowed to run low, which made things worse. The same holds true for any extended life antifreeze. The manufactures claims that their antifreeze formulations last 100K miles has exacerbated these type of problems.
Personally, I think its a mistake to leave any antifreeze in a vehicle for 5 years or 100K miles, even if the label says you can. The PH of the water will go sour (acidic) long before that time, and I believe you really need to change it out every couple of years, regardless of what type/brand you use. Changing out the fluid is the single best way to prevent problems with your cooling system. You get fresh water and antifreeze in the car and remove sediments and the acid build up when you drain it.
Changing it out and getting fresh fluid in it, is IN MY OPINION, far more important than what type you use, and will go a long way toward helping prevent build up in your cooling system. Just be sure to use distilled water to mix it with and mix it in the proper 50/50 formulation. I like to drain and replace mine, drive the car a few days, and then drain and refill it a second time. This helps insure I get all the old stuff out, but doesn't require me to drain the block.
Its your car, do what you want with it. If you think its fine to leave the OEM coolant for the life of the vehicle, then go for it.
I stated my points, and I'm done. I'm not here to argue pointlessly, and I refuse to do so.
I had a water pump changed last week on my 04 Pontiac, and decided to call the shop that did the work on the car (speciality is AC/radiator) and asked him about it. Well it turns out that he only uses Universal Antifreeze. I told him I was concerned that Dexcool wasn't used. He assured me he has never had an issue since he started using it several years ago. Of course he mentioned all the bad facts of dexcool. He has used on all makes with no issues. His shop is always busy. The stuff has a yellow tint, and can be mixed with Dexcool. I looked at Prestones site and their site said the same. Still not 100% on it. I plan on selling this car within a year, so that will be my test. I will use dexcool for the vette.
