Seat memory
Old Jul 14, 2011 | 04:46 PM
MisterC's Avatar
MisterC
Originally Posted by wwwFLA
Do you have memory seat option?
Yes, and it's turned 'ON'. I was fiddling with it in the garage a bit ago and it seems to be working right now.
Old Jul 14, 2011 | 04:51 PM
Chevy Cust Svc's Avatar
Chevy Cust Svc
Like wwwFLA said, you may or may not have the memory seat option. If you do, the instructions are on page 2-66 of your owner’s manual. The controls are located on the driver’s side door.
To program each button, use the following steps:
1. Adjust the settings for the driver’s seat position,
both outside mirrors and the telescopic steering
column position to a comfortable driving position.
2. Press and hold button 1 until two beeps are heard,
then release the button.
Your settings are now programmed.
A second seating, mirror and telescopic steering column
position can be programmed by repeating the above
steps and pressing button 2 for driver 2.
To recall a memory position, do one of the following:
• If you have an automatic transmission vehicle, press
and release the desired button 1 or 2 while the
vehicle is in PARK (P).
A single beep will sound and the memory position
will be recalled after a brief delay.
If the vehicle is not in PARK (P), three beeps will
sound and the memory position will not be recalled.
• If you have a manual transmission vehicle,
press and release the desired button 1 or 2. If the
vehicle is on, the parking brake needs to be
set to recall the memory position.
If the vehicle is on and the parking brake is not set,
three beeps will sound and the memory position
If your vehicle has the Auto Memory Recall feature and
it is turned on in the Driver Information Center (DIC),
the seat, mirrors and telescopic steering column position
will automatically adjust to their programmed positions
when the engine is started. See “Auto Memory
Recall” under DIC Vehicle Personalization on page 3-67
for more information.
To stop recall movement of the memory feature at any
time, press one of the power seat controls, power
mirror control buttons, memory buttons, or the telescopic
steering column switch.
I hope that helps.
Thanks,
Laura
GM Customer Service
Old Jul 14, 2011 | 05:02 PM
MisterC's Avatar
MisterC
Thank you very much, Laura.
