Ign on without running engine?
Old Jul 15, 2011 | 09:45 PM
abstruse1's Avatar
abstruse1
Default Ign on without running engine?
It seems that you need the ign in the run position to do certain things to the car (e.g. DIC setup), but there's no way that I have found to do this without the engine running. In traditional key cars, you could do so.
What am I missing? Is there a way to have the ign in the ON position without the engine running?
ACC position won't do it.
Old Jul 15, 2011 | 09:47 PM
EDinPA's Avatar
EDinPA
Push the on button with your foot off of the clutch.
Old Jul 15, 2011 | 09:48 PM
jeffjob's Avatar
jeffjob
Melting Slicks<br><img src="/forums/images/ranks/3k-4k.gif" border="0">
St. Jude Donor '13, '17-'18, '25
Press and hold acc position for about 15 seconds.
Than yes, you can do DIC setup and other functions.
Accessory mode tales a press and hold for several seconds.
Old Jul 15, 2011 | 09:50 PM
cranky's Avatar
cranky
push on the bottom of the start button and HOLD it down. after 30 seconds or so, the car will be on like you would turn a key to "on". after you are done reading codes or whatever, just hit the bottom of the start button again and it will turn off. hope this helps, i do it all the time on C6's i work on. cranky
Old Jul 15, 2011 | 10:05 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
As noted, press the bottom of the start button once and release for accessory mode. Press the bottom of the start button and hold it for 10 seconds and the car will be placed in ignition on/engine off mode. This will give you complete access to everything you can do with the engine running (DIC personalization, Navigation, etc.) while parked with the engine actually off.
Old Jul 16, 2011 | 12:28 AM
abstruse1's Avatar
abstruse1
Thanx, guys, this is great to know!
Old Jul 16, 2011 | 10:31 AM
C6ToGo's Avatar
C6ToGo
Wow...can't believe no one said.."that's what an owner's manual is for"
Old Jul 16, 2011 | 10:35 AM
Wayne O's Avatar
Wayne O
CF Senior Member
That's what the owner's manual is for.
Old Jul 16, 2011 | 10:49 AM
Mad*Max's Avatar
Mad*Max
Old Jul 16, 2011 | 10:55 AM
inthehunt2's Avatar
inthehunt2
Thanks Talon!
Old Jul 16, 2011 | 12:07 PM
AmmoVet's Avatar
AmmoVet
Originally Posted by Mad*Max
Yeah, and I haven't seen RTFM in a while either!
Old Jul 16, 2011 | 12:10 PM
abstruse1's Avatar
abstruse1
If I missed that in the abusers...oops, I mean owner's manual, I deserve to be beaten to within a millimeter of something by a 20 yr. old gorgeous blond. Or something.
Old Jul 16, 2011 | 01:07 PM
06z06_427's Avatar
06z06_427
Do you need to have the car in acc mode or on to reprogram the tpms?
Old Jul 16, 2011 | 04:54 PM
talon90's Avatar
talon90
NCM Ambassador
To those of you that thought of recommending an owners manual search, good luck. This particular tidbit isn"t in the owners manual, it is a diagnostic tool, not really an advertised feature.
Old Jul 16, 2011 | 05:25 PM
etaylor14's Avatar
etaylor14
Thanks for the info.
Old Jul 16, 2011 | 06:15 PM
abstruse1's Avatar
abstruse1
Ah. I feel better.
To Ign on without running engine?
