C6 computer problem ?
Old Jul 24, 2011 | 03:27 AM
motte's Avatar
motte
4th Gear
Default C6 computer problem ?
4 cylinders are not firing good compression pulled valve covers everything looked good checked fuel inj. good, checked spark good, checked back pressure good, swaped coil packs spark plugs and wires good , computer code is missfire on 5,7 anybody have any suggestions ?
Old Jul 24, 2011 | 03:04 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
(nothing in your profile)
Model?
Mods?
Year of car?
Miles?
Does your car have the 5yr/100k powertrain warranty?
Old Jul 24, 2011 | 09:01 PM
motte's Avatar
motte
4th Gear
05 c6 ls2
Old Jul 24, 2011 | 09:02 PM
motte's Avatar
motte
4th Gear
45k
Old Jul 24, 2011 | 09:07 PM
Jeff78's Avatar
Jeff78
Stock, modified?
Old Jul 24, 2011 | 10:58 PM
motte's Avatar
motte
4th Gear
when i bought the car the seller said it had a rv cam but thats all im aware of
Old Jul 25, 2011 | 09:24 AM
Kenny94945's Avatar
Kenny94945
What is the specific computer code?
Old Jul 25, 2011 | 10:17 AM
pcguy2u's Avatar
pcguy2u
Old Jul 27, 2011 | 05:43 PM
gibear2k5's Avatar
gibear2k5
I just had my computer replaced in my 2008 with 7k miles...it cost me more than 1k at ECS to correct. Hope that's not your problem. Even though I had the car tuned 500 miles ago they told me they had to put it back on the Dyno to retune the new computer.
Old Jul 27, 2011 | 07:40 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I know on the C-5's, there are two ground wires on the rear of the driver's side head that ground the two sets of coil packs. I do not know if its the same on the C-6 and I'm far away from home so I can't go look at my '07 for you. Also, C-5 again, there are fuses for the injectors and I think it was one fuse for each side.
Old Jul 27, 2011 | 08:09 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
Is it 1 bank that is missfiring. I just had a problem like this and it turned out to be the wiring harness on the coil packs. Try switching those and see if it changes anything. I changed both of mine and the newer ones come with a plastic protector that helps to keep th wires from getting crushed by the coil pack. Good luck.
Old Jul 27, 2011 | 08:31 PM
stevefanady's Avatar
stevefanady
I'm having a similar problem with my 09. Stock, misfiring on all cylinders but it starts usually with #7 they still are looking for the issue. Its not injectors plugs or pressure. they say its not the computer as they swapped out with a new one and issue remains.
Old Jul 27, 2011 | 09:57 PM
inthehunt2's Avatar
inthehunt2
To C6 computer problem ?
