top speed
PS-the LS3 has 376 cu in and the LS9 has 376 cu in.
And, by your own admission, you don't know what the top speed of a Grand Sport is. It probably is a tick slower(top speed) then the LS3 in a base C6, but I really doubt it is slower(top speed) then the LS2 base C6.
But, since running our cars at top speed is nearly impossible, it's a moot point. I bet my Z06 LS7 has a higher top speed then your LS3, but I doubt that either one of us have, or will, see our respective car's top speed.
Where in the United States are you legally going to run your car at it's top Speed. I've run on the US's largest and fastest oval track(Talladega) and I hit 162 MPH. A ZR1 hit 167 MPH that same afternoon.
Forum member BEZ06 has hit 175 MPH in his Z06 running around the Daytona speedway, and that was with having to slow down to enter the infield course just past the start/finish line and also having to slow down on the back stretch for a chicane.
As you can see, neither my Z06, the ZR1 or another Z06 can reach anywhere near their claimed top speeds(198 & 205) on the two fastest race tracks in the USA.
I doubt if your base C6 will have a higher speed then a Grand Sport on either of those two tracks and neither one will be faster then the two premium Corvettes, the Z06 and the ZR1. But if it makes you feel better to have the fastest car in your circle of bench racers, have at it.
http://forums.corvetteforum.com/c6-z...-autobahn.html
1. The aerodynamic drag of the wide body GS given the same engine as the base car will mean a somewhat lower top speed. That's not debatable. It's a fact.
2. GM has published top speed information on all C6 models except for the GS. My belief is that's because it's slower than the base model.
As for the LS9 being the same displacement as the LS3, well duh! It's blown for crying out loud.
You must just like to argue for the sake of arguing.
After watching the in car video of BEZ06 running the Rolex24 course at Daytona, I'm heading down(with three additional Corvettes) there in December to run it. I'm hoping to duplicate BEZ06's 175 MPH crossing the start/finish line.
Looking at the numbers, it's hard to determine what the top speed of a Grand Sport might be, based on the improvements in top speed comparing the LS2 to the LS3 to the LS7
From the LS2 400 HP at 186 MPH, GM increased the horsepower by 36 and the top speed gained 4 MPH to 190.
For the Z06 LS7, GM increased the horsepower by another 69, added the wide body and wide tires, and the top speed gained 8 MPH to 198.
Lets review,
1) 36 hp gain = 4 MPH gain in top speed
2) 69 hp gain = 8 MPH gain in top speed.
Double(actually 96%) the horsepower gain and the gain in top speed was doubled.
Doesn't look like the wide body panels and the wide tires hurt the top speed of the Z06. If it had, I would have expected less then 100% MPH gain for the 96% increase in horsepower. So, should the wide body panel and wide tires hurt the Grand Sport? If so, by how much.
I've tried to debate using the numbers provided by GM. Care to respond by using the numbers.
Lets review,
"These engines are hand-assembled at the Wixom, Michigan engine assembly facility by a single technician that signs his work. The extra TLC enables the ’10 Grand Sport to run the quarter-mile in 12.1-seconds at 117-mph – astonishing!"
http://www.corvettereport.com/lookin...he-mighty-ls3/
The batch built assemblers do not do any special hand fitting of pistons to cylinders, or file fit rings, etc. They do not measure each piston and then measure each cylinder bore and then match the pistons to the cylinders, for example. Don't confuse a hand assembled engine with a blueprinted engine.
The reason the LS3 for the dry sump GS is built in Wixom is because of the low volume of engines that are dry sump. It is easier/cheaper for them to batch build the engines then screw up their highly automated assembly lines that produce the standard LS series engines used through the GM lineup.
They already have the facilities to batch build the other dry sump engines at Wixom and the different crankshaft, oil pumps, etc is not really suited for their automated assembly lines.
As my lawyer would say. "It's only fluff and it doesn't' meant a thing", regarding the TLC as stated by GM.
Gm claimed the C5 coupe has a Cd of .29. Then when they introduced the C6 the Cd was claimed to be .287. Noticed how they managed to improve the Cd if only by .003.
A wind tunnel test was done on all five generations of Corvettes in a privately owned wind tunnel that is used by many of the NASCAR teams and other racers.
Their results from taking a stock C5 and a stock C6 off the street and measuring the Cd.
The C5 coupe measured .334.
C5 Z06 measured .373
The C6 coupe measured .343.
C6 conv measured .359
But then the area of the front of the car has to be considered. The C5 has 20.7 sq ft, the C6 has 21 sq ft. So much for the narrower C6 helping the C6. Of course the 1.4 " increase in the C6's height factors into the frontal area.
They didn't measure a C6 Z06 and the tests were performed before the Grand Sport was released for 2010.
I don't know if there is a procedure for standardizing windtunnel test(like the new SAE test for engine dyno's) or if they are like chassis dyno's where you can't really compare the results of two different dyno's, but you can compare different pulls on the same dyno at the same time.
What is interesting is that the C6 has higher numbers then the C5(without the headlights up), unlike what GM claims. Also, when the C6 Z06 was released in the summer of 2005(2006MY) GM said it had a Cd of .31. Later they changed that to Cd .34, They did nothing in the way of changing tires or body panels that would have affected the aero. So, why did they change the Cd? Was it because they said later that the ZR1 had a Cd of .35 and they didn't want it to look as bad compared to the Z06? After all, the ZR1 has a different front splitter, wider tires, running boards and a larger rear spoiler. GM claims the downforce on the ZR1 is much greater the the Z06's.
Would GM fudge the numbers? I don't know.
Reading from the script again?
Lets review,
Wrong direction to attack this from. Even bringing the Z06 into the debate is comparing apples to oranges.
All Corevette are drag limited. Giving the identical HP and Torque curves between between the base and GS with the base having a drag coeficent of .28 and the GS with .32 the GS will be slower. It is simple physics.
But can someone answer this, does the GS have the same gear set as the Z51? If it does it would then be a wash IMO.
Well, I say not only are you a Jackhole, you are a LIAR and of course, a GS TROLL.
