Again!!! CEL is flashing! Help :(
Old Aug 2, 2011 | 11:23 AM
forg0tmypen's Avatar
forg0tmypen
Default Again!!! CEL is flashing! Help :(
I just pulled into my GFs apartment building, and I noticed my car idling rough and some clunky noises coming from the rear as I backed up, don't know if that's related. This has happened before when I installed a used m2w switch, it has since stopped when I installed a new m2w switch. Now it's back....any ideas?
Old Aug 2, 2011 | 11:26 AM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Flashing CEL is major misfire. Check your plugs and wires for a loose connection.
Elmer
Old Aug 2, 2011 | 11:38 AM
forg0tmypen
Do you think it has anything to do with the m2w switch?
forg0tmypen
What are the ramifications of a major misfire?
Old Aug 2, 2011 | 11:41 AM
eboggs_jkvl
Moderator emeritus
Not a flashing CEL unless your wiring job got you in the engine compartment and you messed with the engine area.
Old Aug 2, 2011 | 11:42 AM
eboggs_jkvl
Moderator emeritus
You can break some serious $hit if you keep getting the flashing CEL and drive your car. Get the code read and find out the problem. You are probably getting a 0300 code.
Old Aug 2, 2011 | 11:44 AM
not08crmanymore's Avatar
not08crmanymore
Do you think it has anything to do with the m2w switch? ]
Not likely.All your doing is connecting it to the npp fuse thing.A flashing light is bad news.02 SENSOR,MISFIRE,something.stop driving the car or major damage may occur!!
Old Aug 2, 2011 | 11:48 AM
forg0tmypen
What is an 0300 code?
Old Aug 2, 2011 | 11:49 AM
Top_Fuel's Avatar
Top_Fuel
A flashing CEL is the PCM's way of alerting you that the misfire is so bad, that unburned fuel is likely getting dumped into your catalytic converters. Your converters will burn the unused gas, but that's not what they were designed to do. They can become damaged if you ignore a misfire because they will overheat from trying to consume all the fuel that the engine should be burning.
P0300 Code
Go get your codes read!
Old Aug 2, 2011 | 11:51 AM
Cruncher's Avatar
Cruncher
It means for you to go to your Porsche dealer & get a Cayman S in order to avoid future headaches & consistently lousy "Certified Service" service.
Old Aug 2, 2011 | 11:52 AM
not08crmanymore
call a tow truck.Your manual says to STOP DRIVING IMMEDIATELY if that light is flashing.Any car is pretty much the same with that light flashing.You under warranty??If so,quit dicking around and get it too a dealership.After removing the M2W of course.
Old Aug 2, 2011 | 12:00 PM
P0234's Avatar
P0234
You have a $50k car, live a little and spring for a $30 code reader....
http://www.amazon.com/Autel-MaxiScan.../dp/B001LHVOVK
Old Aug 2, 2011 | 12:38 PM
forg0tmypen
Ok just for the hell of it I uninstalled the m2w and let the car sit a while and when I started it up, the cel went off.....??? Now I have no engine light at all...I'm not under warranty and I haven't driven it since it came on...
Old Aug 2, 2011 | 12:41 PM
eboggs_jkvl
Moderator emeritus
This makes no sense at all. The M2W is the exhaust and should not be causing a CEL if it is wired properly.
Elmer
Old Aug 2, 2011 | 12:43 PM
nmerhaut's Avatar
nmerhaut
If you have an active OnStar acct, call them and they'll tell you what it is.
Old Aug 2, 2011 | 12:44 PM
carpe dm's Avatar
carpe dm
You say you started it, is it still missing?
Old Aug 2, 2011 | 12:47 PM
forg0tmypen
I agree with the code reader I need that. I think I'm going to have it towed...
To Again!!! CEL is flashing! Help :(
Old Aug 2, 2011 | 12:49 PM
forg0tmypen
No cel on at all now...since I uninstalled the m2w.... Should a flashing cel ever shut off? Is that a good thing?
Old Aug 2, 2011 | 02:02 PM
P0234's Avatar
P0234
Its hard to say without knowing the codes. It just seems to strange that the switch would be causing misfires unless there is some real wiring weirdness going on.
Old Aug 2, 2011 | 02:05 PM
Top_Fuel's Avatar
Top_Fuel
Yes...it means your car is apparently no longer misfiring.
If your misfire is somehow linked to your M2W install, there is some serious weirdness going on.
