Lightning Strike?
Old Aug 4, 2011 | 12:56 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Default Lightning Strike?
I've always thought the windshield frame + halo in a coupe, or steel frame for the canvas in a vert, would protect us from a (very rare) possibility of a lightning strike.
But in a Q&A about lightning in today's Chicago Tribune, it says:
"Am I safe during a thunderstorm if I'm in a car?"
"That depends on whether your car has a metal roof. A car's metal roof and sides protect occupants from lightning by directing the electricity through the car's frame and into the ground. You're not protected if you're in a convertible or on a motorcycle. Rubber tires don't offer protection."
We know the newspapers always get it right...
I'm guessing that GM has done some testing, but not sure if they release the results.
Anyone know for sure?
Old Aug 4, 2011 | 01:16 PM
rchbn's Avatar
rchbn
Electricity takes the shortest path so if your car was struck it would go though the halo and then to ground. If your that worried about it put a handsome looking CB antennae on the roof and run the wires through the path that you can repair the easiest.
Old Aug 4, 2011 | 01:23 PM
Larry/car's Avatar
Larry/car
What about meteorites? You could be hit at any time.
Old Aug 4, 2011 | 01:37 PM
RAT's Avatar
RAT
Yeah, that's a big concern for me. I've been hit a couple times in the head by those buggers.
Old Aug 4, 2011 | 01:41 PM
Mikev078's Avatar
Mikev078
What about mind control? Let the government conspiracies commence
Old Aug 4, 2011 | 02:08 PM
fnsblum's Avatar
fnsblum
"Am I safe during a thunderstorm if I'm in a car?" You are safer than many objects around you. A very close or direct hit you will be toast. I have been very close to a big strike. It was an explosion. Good luck with your #22 wire carrying several million volts to ground. Later! Frank
Old Aug 4, 2011 | 02:18 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
Have a read of this thread:
http://forums.corvetteforum.com/c6-c...-lighting.html
and more importantly, the reply (post 44, page 3) by Shopdog which I've quoted here:
Originally Posted by Shopdog
I suppose I should comment. I wrote one of the commonly referenced texts on lightning effects and lightning protection, so I do know a few things about the subject.
First of all, lightning can travel miles through open air, a little thing like a rubber tire won't inconvenience it. Trees are the most commonly struck natural objects, and wood is not much better of a conductor than fiberglass. Neither is as good an insulator as air, and as noted above, lightning has no trouble travelling through miles of open air. When you are dealing with voltages in the hundreds of millions of volts range, and currents approaching 20,000 amperes, our common sense notions of electricity derived from our experiences with low voltages aren't too good a guide.
The best thing to have around you when lightning is near is a full metal cage. Not much can insulate against the voltage of a lightning bolt, but the Faraday cage effect works very well to keep charge outside a metal structure. Charge only exists on the outer surface of a closed metal object because charge is free to move in metal, and like charges repel, so the charges try to get as far from each other as possible, that means they stay on the outside. So things inside a closed metal object are essentially immune to the effects of lightning. That's why it is extremely rare for the electrical systems of ordinary metal bodied cars to be affected by lightning. However, a plastic body offers no Faraday cage shielding from lightning.
Lightning does follow electrical law. It will take the lowest resistance path between two points. (It'll also take every other path between those points, with the current of the bolt dividing in inverse proportion to the resistances of the paths in accord with Kirchhoff's law.) Since a tree, person, or car is a lower resistance path between Earth and sky than open air, more of the lightning's current will flow through these objects than will divert through open air around them. The only way to avoid being a primary conductor of lightning is to have a much better conducting path nearby which will hog the majority of the lightning bolt's current. Lightning rods are protective for this reason. They offer a very much better conductive path to Earth than do the structures to which they are attached.
Now lightning doesn't have to directly strike an object to have an effect on it. The 20,000 ampere current of the strike generates an electromagnetic pulse which can induce massive currents in nearby conductors (and less substantial currents in more distant conductors). The latter is the source of the "crashes" you hear on AM radio when a thunderstorm is in the area. But a near strike can induce currents strong enough to do damage to electrical systems. This is probably what happened to the poster's car. Induced currents in the wires of the car damaged some sensor or an input port on one of the computer modules. (Or perhaps the surge only triggered an alarm in some circuit, which will clear on its own after a certain number of start cycles have occurred.)
Old Aug 4, 2011 | 02:25 PM
davidtcpa's Avatar
davidtcpa
Go Canes!
St. Jude Donor '11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21
It's a good thing my car melts in the rain. Otherwise driving it in Florida (lighning capital) could get me in trouble!!!
Old Aug 4, 2011 | 02:32 PM
5knives's Avatar
5knives
Just install a long metal rod and connect it to a flux capacitor installed in your car so if by some chance you do get struck by lightning, you can travel back in time to before you were struck and warn yourself not to travel in that area. Of course if you don't travel that same path you wont get struck by lightning and go back in time so you wouldn't be able to warn yourself not to take that path thus causing you to get struck by lightning, which would in turn send you back in time where you....
and so destroys the space-time continuum
Actually that's a good read. I'm sure (hope?) the OP isn't obsessively concerned about being struck by lightning but is merely bringing up an interesting possibility.
Old Aug 4, 2011 | 02:41 PM
Gearhead Jim
St. Jude Donor '13
I'm not worried about meteorites, that Lexan top is really strong!
As for the lightning issue, after reading the replies here and the entire thread that Paul referenced; I still don't know if the Tribune article was correct or not.
Old Aug 4, 2011 | 02:44 PM
Gearhead Jim
St. Jude Donor '13
No, not obsessing about it at all. The chances of a strike in the Corvette are not 0, but are so small that I rate them only a little higher than the meteorite problem.
But it's always nice to know, we drive our C6 in any kind of weather on road trips, and have been caught in some massive midwest thunderstorms.
Old Aug 4, 2011 | 02:54 PM
talon90's Avatar
talon90
NCM Ambassador
Jim, I think the correct answer is that the newspaper got it partly right. If you read Shopdog's section on Faraday cages, this is what the author of the newspaper piece was alluding to. Electricity will move in the path of least resistance and because of properties of charges, will be forced to the outside of the metal structure (sometimes referred to as the skin effect in electrical wiring). Metal roof, metal framed, metal bodied cars will do more due to these properties of electricity. I think that if a charge were to hit our A pillar directly you'd have a better chance then if it hit the center of our roof panel. We do have some aluminum, magnesium and steel surrounding us in our cars along with air but we also have some plastic and composite that are still lower resistance than air.
Old Aug 4, 2011 | 03:12 PM
Ghost 23's Avatar
Ghost 23
When my time comes, I think a lightning strike would be a quick way to go, as opposed to a slow and painful death.
Old Aug 4, 2011 | 03:16 PM
Gearhead Jim
St. Jude Donor '13
I can remember pics in National Geographic about 50 years ago of cars being tested in a "lightning chamber", all we need is a chamber and a volunteer.
During my airline career I can recall having several "static discharges", somewhat like a smaller reverse lightning strike. Exciting but usually no damage. To my knowlege, I never took an actual lightning strike in over 25,000 hours of flying.
Old Aug 4, 2011 | 04:48 PM
dvilin's Avatar
dvilin
Old Aug 4, 2011 | 07:27 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
I miss Shopdog, but appreciate the quote of the article, Paul. Since his treatise is that it will follow the path of least resistance, seems to me it will hit maybe both at the same time. The roof and the halo or A pillar. Who knows? I sure don't want to be in the car when it hits, but now saying that....I will be! oh darn...
Old Aug 4, 2011 | 08:27 PM
Marc V.'s Avatar
Marc V.
I don't know about the occupants, but I can tell you lightning wreaks havoc on a vehicle.
I work for a dealership, and we have 2 cars in the shop now that were hit.
It blew out ALL the modules, the alternator, fuse box, almost anything in the electrical system.
The insurance company totalled one truck because cost of parts and labor to repair exceeded value of the truck.
To Lightning Strike?
Old Aug 4, 2011 | 10:53 PM
Gearhead Jim
St. Jude Donor '13
Does anyone know what happened to shopdog? I didn't always agree with him, but his posts wre worth reading.
Old Aug 4, 2011 | 11:49 PM
cclive's Avatar
cclive
In unison and with a blank stare: "The Press are always right. We must all believe what they tell us. They are the smart ones and would never mislead us..."
And no meteorite could possibly get through the clear top...it's Lexan and that is what bullet proof glass is made of....
Old Aug 5, 2011 | 05:20 AM
foremaw's Avatar
foremaw
Active Streak: 90 Days
St. Jude Donor '08-'09-'10-'11-'12
Another good reason not to take the car out in the rain.
