Problem Solved, Time to Wait Though...
A broken valve spring started the all the trouble, so Stephen and Jason at England Green helped get the repairs underway.
They pulled the head's off after a leakdown test revealed a bent valve. Definitely an eyebrow on the faulty cylinder.
What is troubling though, is there is some intake valve impact on the other cylinders even though the springs were intact. Suspect that either the original setup was not done properly or there may be a timing chain issue.
The head's are in good shape, but are going to be cleaned up and inspected.
Since we've already gone this far, we're going to pull whatever cam is currently in there, setup the tolerances properly and put a new Mayhem II cam in there.
Now I just have to wait ~2 weeks.
Maybe the RPM's were too high and you floated the valves and that cause the valve to piston contact. If that's the case then maybe the heads should be disassembled and all the valves checked. Are they replacing the piston on the cylinder with the broken valve spring? The reason I ask is because years ago I dropped a nut from the air cleaner rod down the carb without knowing it. Found it when I heard the racket it made when it got into a cylinder. It ended up getting wedged in the spark plug gap but didn't know until I'd pulled the head. After reassembly there was a slapping sound from that side of the engine. Had to pull it all apart only to discover that the piston was damaged more than was visible by just looking at it, which only showed a few impacts from the nut. Turns out the skirt broke loose from the top and the top was broke in three pieces with only the rings holding it together. The slapping noise was the skirt hitting the upper half of the piston as the engine turned over.
Just something to think about before you have it all put back together. Would hate to hear you had to have it pulled apart after putting it all back together.
Maybe small claims court could be enough to cover this. Many states require dealers to warranty.
The real pain of it was the dealer only listed that it had exhaust, headers, and a stall converter. No mention of the cam, heads, and supporting mods. Dealer didn't know what they had, and also talked out of their **** about the warranty work.
As for the ding in piston #4, it looks aweful in the picture, but when I saw it in person it feels like a like scratch more than a true ding. I was advised by Stephen to not mess with it as he didn't think the impact really did anything to the piston.
